sled pulling
sled pulling
Postby flyinredneck » Sun Jul 24, 2011 12:14 am
when you guys start do you recomend boosted or non boosted launches? what is easier on the drive train?
1992 w250 stock straight pipe with pump a lil tweaked denny t stage 2 fuel pin fuel screw at 3 turns
flyinredneck
Re: sled pulling
Postby Hansen01 » Sun Jul 24, 2011 9:25 am
auto or manual? i have a manual and i cant do boosted launched even if i tryed without totally smokin the clutch :D
Under construction...
Hansen01
Re: sled pulling
Postby ahale2772 » Sun Jul 24, 2011 6:43 pm
wait how are you "boosting" with a 6 speed? hope your not slipping the clutch to get the psi's to come up?... :shock:
with mine I just flat footed the right pedal, let the clutch grab then let her loose, took me a few tries, with a heavy sled your brain wants to slip the clutch more, but if you rev the piss out of it the wheels will usually spin before you bog
Re: sled pulling
Postby oldestof11 » Sun Jul 24, 2011 6:52 pm
^ Holy drive line shock! :shock:
What I did, I did on a 180k+ mile stock Sachs clutch.
Put it in 2LO and either 2nd for hard or 3rd for loose track. Get RPM's up a bit like you are gonna pull out a stuck buddy. Around 1500-1800 is about where it was. As I let out the clutch the 1st time I pulled, I did what everyone said, I slipped until it hooked (about 20ft-50ft) and the floored it. I was 1st and didn't like my 192ft so I came back last. Tried 3rd but sled was set heavy for a short track. I got it back into 2nd, got RPM's up, and slowly let out the clutch. As soon as the sled moved 10ft, I dumped the clutch and floored it. Bogged, bucked, and took off.
When I wrecked the truck 3 weeks later, after 1 more pull, there were 3 spots on the pressure plate where it was blue and about as big and as long as my thumb. The clutch was down to the rivets. :lol:
Re: sled pulling
Postby Hansen01 » Sun Jul 24, 2011 7:02 pm
sorry sorry sorry! i forgot a T on the word cant :oops: lol
i can not do a boosted launch without horribly slipping the clutch ;)
Hansen01
Re: sled pulling
Postby Hansen01 » Sun Jul 24, 2011 7:05 pm
when i did that with my five speed it was a hard track and i could alllmost start out in third gear but it never did work, even after it rained :?
second low in it was way to slow lol i also take off the line at anywhere between t and 2400 rpms :D
Hansen01
Re: sled pulling
Postby ahale2772 » Mon Jul 25, 2011 10:56 am
Well I do have a Bit bigger clutch, so I beat the he'll out if it, rather bust a ujoint than slip a pricey clutch
Re: sled pulling
Postby flyinredneck » Tue Jul 26, 2011 4:14 pm
this is all good info but i have an auto lol
flyinredneck
Re: sled pulling
Postby Hansen01 » Tue Jul 26, 2011 4:26 pm
id say boosted :D
Hansen01
Return to Competition
