Front traction bars
Re: Front traction bars
Postby Kasper Cummins » Sat Sep 10, 2011 7:19 pm
stillsmokin wrote:I see your point, however you do realize the reason the axle is wrapping right? Look at the distance from the top leaf to the axle tube, that is a long lever perpendicular the spring. You have to control the wrap below the axle tube with our problem, if you mount a bar over top of the axle the results will be much less effective.
Yes, I agree.
But why do you feel the front axle should be setup different then the rear axle. They are both doing the same thing.
92 W250 club cab
Kasper Cummins
Postby KTA » Mon Oct 17, 2011 7:07 am
I used the mounts and stabilizer bars with the rubber bushings from a 2wd Dodge on my 4wd competition truck. I also installed a full length heavy leaf under the top leaf to give support from shackle to shackle. I don't think the axle can wrap now.
Return to Competition
