Pulling turbo ?
Pulling turbo ?
Postby Haywagon » Tue Sep 27, 2011 12:49 pm
Hey guys time to spend some money im lookin to build a pulling / street truck . I want to be able to be comp at pulling but still be able to street it as a toy . I am thinking 6x16 with a 62/80/14 phat shaft turbo and supporting mods... Piston pump , fass , ARPs, and valve springs will this be a good set up or should something/s be changed i want to play and pull trucks a toy wanna have funn let me know what you think any ideas would be great !
Aaron
1992 reg cab 4x4 getrag 165K
Intake
4" pipe
366 spring
33x12x18 mud grapplers on 18x10 KMC Spy
Haywagon
Re: Pulling turbo ?
Postby dazedandconfused » Tue Sep 27, 2011 1:10 pm
If it's just a toy and you don't haul with it I'd go bigger then a 62. I'd go for a 66 and a nice cam to help spool
Re: Pulling turbo ?
Postby Haywagon » Tue Sep 27, 2011 4:46 pm
A 66 wont black out the sun bombin around town ? Is the 62 too small ? Any better turbo options maybe cheaper or better spooling / power ?
Intake
4" pipe
366 spring
Haywagon
Re: Pulling turbo ?
Postby dazedandconfused » Tue Sep 27, 2011 5:02 pm
It's going to stay hot with that small turbo and big sticks just ask Richie O.
Re: Pulling turbo ?
Postby oldestof11 » Tue Sep 27, 2011 5:08 pm
62 sounds small... 66 is big... 64?
Re: Pulling turbo ?
Postby Haywagon » Tue Sep 27, 2011 5:14 pm
Ya what size tho 66/70 or 66/80 then 12 cm or 14 cm
Intake
4" pipe
366 spring
Haywagon
Re: Pulling turbo ?
Postby Haywagon » Tue Sep 27, 2011 5:19 pm
And any diff between phat shaft super p.s/s. Bullet and the 64/80/14 looks like a good choice still new to this whole power thing :mrgreen:
Intake
4" pipe
366 spring
Haywagon
Re: Pulling turbo ?
Postby delinquent » Wed Sep 28, 2011 12:11 pm
to be competitve around here most use a Columbus Hx60 or a Garrett based Precision. Those are both at least $3500 chargers.
If I were you, I would do a search for Borg-Warner S366. Reasonable price, decent manners without a trailer, makes plenty of power for a "toy."
delinquent
Re: Pulling turbo ?
Postby Haywagon » Wed Sep 28, 2011 4:54 pm
thanks for the info ya not huge number or dedicated puller yet ( p pump later ) but i like the idea from earlier with the 64 any one have experience with any phat shaft turbos on a first gen?
Intake
4" pipe
366 spring
Haywagon
Re: Pulling turbo ?
Postby dazedandconfused » Wed Sep 28, 2011 5:10 pm
Check out forced inductions for chargers at a good price.
Re: Pulling turbo ?
Postby mprmn08 » Sun Oct 30, 2011 1:26 pm
for a good street turbo that makes good power to pull with check out engineered diesels 63mm. it supports up to like 650hp spools faster then a 62 and flows for then a 64mm. They are local to my shop so we have been working with them selling there turbos. that one is a dang good turbo for the price. they are around 13-1500.
mprmn08
Re: Pulling turbo ?
Postby KTA » Mon Oct 31, 2011 10:36 pm
I ran a 62 x 71mm S300 and made 488hp and over 1200ft-lb. It cleaned up my 12mm pump. For a 12mm ve I would never run anything bigger.
Re: Pulling turbo ?
Postby Haywagon » Fri Apr 12, 2013 3:38 pm
KTA what size sticks for the 62/71 ...5x14 work ? Whos turbo ... HTT,ED,II ?
Intake
4" pipe
366 spring
Haywagon
Return to Competition
