1st Gen 1/4 Mile times
Re: 1st Gen 1/4 Mile times
Postby oldestof11 » Sun Feb 05, 2012 7:55 am
Shee it!
Sounds like my dads old Nova. Doesn't remember what he did to the car other than the usual carb, headers and cam. He thinks he did a few more things to it but can't remember. The car did a 14sec @ 120mph. Wouldn't hook till 4th gear on the largest street tire he could find. I wish I had that car.:(
Postby oldestof11 » Sat Apr 07, 2012 2:44 pm
Ran a new best of 15.94. Only thing changed was drilled banjo bolts, fixed AFC line, and added a 140lbs passenger. Almost beat a Mustang but when I went to shift into 4th, the shifter came loose and just rotated. :evil:
My brothers 03 6.0L ran a 14.1 on just a tuner and EGR delete... Beat a brand spanking new Camaro SS with 500 miles on it. All 4 tires sorta jumped off the track when he launched. :shock:
Postby JustinRhodes » Sat Apr 07, 2012 5:23 pm
Since we don't have a 1/4 mile around here, I figure I'll post my 1/8th
8.537 @ 82 mph
http://www.youtube.com/watch?v=fOP1fTzRzjY
JustinRhodes
Postby dazedandconfused » Sat Apr 07, 2012 7:57 pm
[url][/url]
JustinRhodes wrote:Since we don't have a 1/4 mile around here, I figure I'll post my 1/8th
8.537 @ 82 mph
Did it short shift 2nd to 3rd?
Postby JustinRhodes » Sun Apr 08, 2012 5:00 am
It did very bad. Ratchet shifter on the way soon though to fix that 8) Also with a new vb so I can lock it up in 2nd with the shifter in 2nd. I guess I could shift it manually on the column but I'm scared I'll throw it up to far and hit reverse :shock:
JustinRhodes
Postby dazedandconfused » Sun Apr 08, 2012 5:47 am
I thought it did. Sounded like soon as it hit second it went ahead and jumped to third.
Postby JustinRhodes » Sun Apr 08, 2012 9:55 am
dazedandconfused wrote:I thought it did. Sounded like soon as it hit second it went ahead and jumped to third.
It did pretty much, unsure why it does it though. Ratchet shifter should take care of it, but I wont be able to lock it up in 2nd.
JustinRhodes
Postby dazedandconfused » Sun Apr 08, 2012 9:59 am
Have you messed with TV cable adjustment.
Postby RumbleFish » Sun Apr 08, 2012 10:21 am
My dads dakota traps 118, but runs 10.80s. Its also putting down 1.6 60' times
Postby BC847 » Sun Apr 08, 2012 11:45 am
Green . . . . 8)
Postby JustinRhodes » Sun Apr 08, 2012 2:33 pm
dazedandconfused wrote:Have you messed with TV cable adjustment.
Tv cable has been adjusted 100 times, when the torque converter is locked, it just shifts out of 2nd REALLY fast. If you leave it unlocked it works like it should.
JustinRhodes
Postby dazedandconfused » Sun Apr 08, 2012 2:35 pm
Sounds lime a valve body issue
Postby JustinRhodes » Sun Apr 08, 2012 3:07 pm
dazedandconfused wrote:Sounds lime a valve body issue
I wish I could tell you what vb it had in it, but I'm not sure. Thats another reason im switching to a dtt valve body.
JustinRhodes
Postby JustinRhodes » Mon Apr 09, 2012 3:41 pm
Also BC congrats on breaking into the 7s 8) Id like to get there one day :roll:
JustinRhodes
Postby oldestof11 » Mon Apr 09, 2012 4:00 pm
David, what's with the LONG reaction time??? You could have had that other vehicle...
Return to Competition
