1st Gen 1/4 Mile times
Re: 1st Gen 1/4 Mile times
Postby skilletky » Thu Nov 29, 2012 9:59 am
a little more tuning, better shifting, and leaving the line with a little more boost should put me in the 12's, hopefuly.
skilletky
Postby BC847 » Thu Nov 29, 2012 2:20 pm
skilletky wrote:a little more tuning, better shifting, and leaving the line with a little more boost should put me in the 12's, hopefuly.
Is that an automatic?
It's quick! 8)
Postby skilletky » Thu Nov 29, 2012 2:22 pm
yeah, its a 518 built (ha ha) by ATS with one of their converters
skilletky
Postby dazedandconfused » Thu Nov 29, 2012 2:35 pm
Have any luck getting it to hook up any better?
Postby skilletky » Thu Nov 29, 2012 2:46 pm
dazedandconfused wrote:Have any luck getting it to hook up any better?
no, the slip i posted was the last run i made with it. was going to single the rears out and try to loose a little more weight, but i started working later on fridays and never got to go back to the track. i messed with the afc pin and spring last night, and took some timing out of it and it feels like it pulls harder down low and up top. i think i may have had too much timing. when i put the new injectors in, i left the timing where it was set for the old injectors. i may go ahead and buy a new controller for the W/M so it will work and shoot a 50/50 mix at it. when the W/M did work, it made a big difference in the high rpm's for me, but it aint worked in forever.
skilletky
Postby 1STGENFARMBOY » Thu Nov 29, 2012 10:54 pm
I have seen the truck, very very deceiving looking truck, i'm gonna say you can have some fun with it on the street...
.....not that i condone street racing. 8)
i think 12 is in the neer future.
Postby skilletky » Fri Apr 05, 2013 6:17 am
headed to the track today after work. hoping to get at least a 12.99. gonna skip the burn out and not spool up so long. i pulled the deer slayer off the front and removed the tail gate to shed some weight. gonna weigh it before i head to the track. any other pointers yall got?
skilletky
Postby oldestof11 » Fri Apr 05, 2013 2:26 pm
Lower tire pressures?
Postby Sutter1stgen » Fri Apr 05, 2013 3:00 pm
Enough fuel in the tank to not run the pump dry. Remove tow package and spare tire if it still has them.
Eric
Sutter1stgen
Postby skilletky » Fri Apr 05, 2013 6:25 pm
13.2 at 106 with no traction. Had to let out twice to get it to hook. Trans messed up. Reverse is messed up bad and 1st gear ain't right now. Ran it a second time , 13.6 at 107 with same traction issues. Need some slicks
skilletky
Postby dazedandconfused » Fri Apr 05, 2013 6:32 pm
You kill the 518?
Postby dazedandconfused » Fri Apr 05, 2013 6:33 pm
Chris Thorn hill opens tomorrow as well with test-n-tune.
Postby skilletky » Fri Apr 05, 2013 6:43 pm
I think it's about to go. It still goes forward somewhat ok. It's still under warranty. I thought about going to thorn hill , but I got a lot to do Tom, headed down to Florida Tom night or Sunday morning
skilletky
Postby dazedandconfused » Fri Apr 05, 2013 6:48 pm
Sounds like its time to give old ATS a call.
Postby skilletky » Fri Apr 05, 2013 6:52 pm
Yeah. I hope they fix it. I really need to get a lock up trans.
skilletky
Return to Competition
