3:07 gears
3:07 gears
Postby fatstack » Fri Mar 02, 2012 5:23 pm
Would 3:07 gears make my truck faster ?
89 d250 getrag ripper, pump maxed,timed to the head,pull cable shutoff, 354 spring, straight pipe, 4:10 gears, in the shop: he351cw and 3:07 gears
90 w350 nv4500,ic motor, stock, 5" stack w a western hauler on back
fatstack
Re: 3:07 gears
Postby RumbleFish » Fri Mar 02, 2012 5:34 pm
Faster? Yes. Quicker? No.
Re: 3:07 gears
Postby fatstack » Fri Mar 02, 2012 6:02 pm
Yes sir. In the 1320
fatstack
Re: 3:07 gears
Postby gobigorgohome » Mon Mar 05, 2012 5:24 pm
fatstack wrote:Would 3:07 gears make my truck faster ?
you can only get them used now. i coulnt find any when i crunched my last set
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Re: 3:07 gears
Postby cmann250 » Mon Mar 05, 2012 6:19 pm
Keep in mind that the 3.07s need the D61 and D71 axle. I don't think you can go from 4.10s to 3.07s. You'd need a whole different rear end. The 3.07 gears are physically bigger I believe
Re: 3:07 gears
Postby gobigorgohome » Wed Mar 07, 2012 1:25 pm
i have my old 3.07 ring and pinion if you need some measurements done.....
gobigorgohome
Re: 3:07 gears
Postby fatstack » Thu Mar 08, 2012 8:33 pm
Snagged a rear end today for $150 yeehaw! What should i check/replace before i bolt It up? Thanks
fatstack
Re: 3:07 gears
Postby dazedandconfused » Fri Mar 09, 2012 3:21 am
I'd go ahead and rebuild it personally. New bearings and seals since the 3.07 gears are getting harder to find.
Return to Competition
