sigma pump
sigma pump
Postby DTanklage » Fri Sep 28, 2007 7:53 am
how crazy are they?
don
DTanklage
Postby KTA » Fri Sep 28, 2007 11:51 am
About $8-10000 crazy. They are big nasty pumps that throw a ton of fuel and do it quick. Hypermax also makes their own version as well as the original Frenchie. They would be totally undriveable and have terrible governor control.
Postby Begle1 » Mon Dec 24, 2007 10:32 am
These are injection pumps?
Postby cummins king » Wed Dec 26, 2007 4:20 pm
i think this is what your talking about
http://www.competitiondiesel.com/forums ... 950&page=2
93 4X4 auto
cummins king
Postby Fnschlaud4620 » Tue Jan 08, 2008 10:22 am
Could it be possible to get a custom built SMALL Street friendly version of this pump made to take advantage of the quick injection time?
I have seen quick cut cams for the p7100. Usually they go with 13mm B&P from my research, and they are said to be race only pumps. But how would a quick cut cam work in a p7100 with 12 B&P?
I guess my real question is using X amount of fuel how does the time of injection affect the situation?
Thanks
Fnschlaud4620
Fnschlaud4620
Postby KTA » Tue Jan 08, 2008 9:52 pm
Every engine has an optimum amount of degrees for injection to occur. Say for the 5.9 it is 40deg. If you are injecting a small amount of fuel you will need a slower cam than if you are trying to inject a lot of fuel. If you put a fast cam with a small amount of fuel it generaly hurts performance because now your delivery is only say 10deg instead of 40, so you get real spikes in the cylinder pressure rather than a nice smooth push. That is the most generic explination I can give, its really much more complicated.
Return to Competition
