First pull with twins
Postby motorwood » Sat May 19, 2012 6:28 am
I'm pulling tonight with an hx60 over a 366. Should be very interesting. I think it's gonna do well or break, can't wait to feel 80lbs boost while hooked to a sled. :)
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Re: First pull with twins
Postby ellis93 » Sat May 19, 2012 6:34 am
80lbs! :shock: can't wait to hear how it goes :bom:
Postby dazedandconfused » Sat May 19, 2012 6:40 am
Where are you pulling?
Postby motorwood » Sat May 19, 2012 6:59 am
A small town in south central PA. They're letting us street guys kinda go run what ya brung.
motorwood
Postby motorwood » Sun May 20, 2012 4:23 am
328' best pull by far.
motorwood
Postby 1STGENFARMBOY » Sun May 20, 2012 5:07 am
video ? ? ? ? ?
Postby ellis93 » Sun May 20, 2012 6:10 am
Nothing broke? Good deal :grin:
Postby ahale2772 » Mon May 21, 2012 4:54 pm
Motorwood, You've got me thinking about how long my input will stay alive above 400HP...I hope it does....
Edit... when they do twist, will the clutch stay engaged because it cant slide back on the input?
Postby motorwood » Tue May 22, 2012 5:57 am
It will break in the splines most likely. The plate(s) will stay put other than the splines may mis-align. So if your clutch pedal won't push, forcing it (to activate the safety switch to start the truck) will bend the disk(s). If you keep your foot out of it below 2000 rpm and don't dump the clutch, it may last a long time.
motorwood
Postby Tacoclaw » Tue May 22, 2012 8:47 am
Cool stuff, Motorwood!
How'd you place with a pull like that? I figure to get much past that they'd be pulling the sled around the parking lot.
Postby motorwood » Thu May 24, 2012 11:58 am
4th of about 19
motorwood
Return to Competition
