can i pull?
can i pull?
Postby jacobwebb57 » Mon Jul 16, 2012 3:46 pm
i have never pulled this truck i have pulled my buddies 97 before and an 03...but never my 91.5..i have everything in my Sig plus head studs traction bars and a new clutch on the way...i got 2 weeks till the pulls at my county fair..idk if it will be ready by then but i wanna try...what do you guys think
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: can i pull?
Postby oldestof11 » Mon Jul 16, 2012 4:36 pm
2nd 4 low is all you will be able to do.
I bring the RPMs up to 2000-2200, let the idle drop but keep the same throttle position as I let out the clutch, by 20-30 ft I have the skinny pedal mashed and the clutch engaged. I have pulled 5 times and numerous passes on the stock clutch and it still holds true.
Re: can i pull?
Postby Hansen01 » Tue Jul 17, 2012 9:08 pm
Go for it!
And yea 2nd low is all ive ever been able to get out of my 5 and 6 speed, have gotten 3rd out of my 6 speed once...
Under construction...
Hansen01
Re: can i pull?
Postby ahale2772 » Wed Jul 18, 2012 8:47 am
if hes got 4.10's he may be able to pull 3rd low, what does the truck have for axle gears and what size tire?
Re: can i pull?
Postby cmann250 » Wed Jul 18, 2012 1:07 pm
A couple of tricks I'd try are throw weight in the bed and passenger side of the cab. I doubt they'll let you hang weight, but these trucks are super light and they could use it. I'd also try to slide the hitch up as far as they allow to get better weight transfer.
Also, just my $.02, I wouldn't pull on a brand new clutch. I'd tear up the old one
Re: can i pull?
Postby stillsmokin » Wed Jul 18, 2012 8:57 pm
Put a tool box in it, put wood under it so it dont break the box sides or the tool box. Stuff it full of heavy crap and say thats how you drive around all the time. Put the tractor weights at the bottom and chains / jacks etc on top. I had my stock clutch burn up 90ft out years ago, never slipped once till then, $.02. The smell lasted 2 weeks. How I don't miss those early days.
92 W250LE REG CAB, SLED PULLER, S400
93 W350LE EXT CAB, dually, 5 speed
stillsmokin
Re: can i pull?
Postby pulltilbroke » Wed Jul 18, 2012 10:38 pm
Quit givin away all my secrets Jeff.
Re: can i pull?
Postby Hansen01 » Thu Jul 19, 2012 11:22 am
pulltilbroke wrote:Quit givin away all my secrets Jeff.
Hansen01
Re: can i pull?
Postby oldestof11 » Thu Jul 19, 2012 2:20 pm
I have chain, a couple bottleneck jacks, a "racing" jack, a turbo, and various tools in mine. Only got me 6200lbs at the last pull. The guy asked me what class I was pulling. "Stock Diesel" I told him. His response: "Do YOU know what class you are pulling AGAINST?!?!?" I laughed and told him I was there for a good time. He laughed and said that is what mattered.
Re: can i pull?
Postby ahale2772 » Thu Jul 19, 2012 6:04 pm
I'm pulling sunday, hoping to try and pull 3rd gear low...? anyone think I wont be able to?
19.5's, (come out to a 33" tire) 3.54 gears.
Re: can i pull?
Postby jacobwebb57 » Fri Jul 20, 2012 11:38 am
so as much heavy sthi as i can fit in my tool box and senond low....it has 410s and 34s
jacobwebb57
Re: can i pull?
Postby oldestof11 » Fri Jul 20, 2012 12:31 pm
I have 33's and 4.10's. 3rd low is too much.
Re: can i pull?
Postby pulltilbroke » Sat Jul 21, 2012 9:26 pm
Takes a lot of power or a very loose track to pull 3rd with 3.54 on a 205.
I will also be pulling tomorow. Hopefully it don't bounce.
Re: can i pull?
Postby ahale2772 » Mon Jul 23, 2012 8:46 am
Pulled twice this weekend, first time I weighed 7200 lbs in an 8500 work stock class, only pulled 49 feet. the sled was a "drop" sled and the track was dry and loose. had 70 psi in all my tires.
had plenty of rpm/wheel speed/power.
second pull, third gear, low, sidestepped the clutch, brought the front tires down to 10 psi, rears at the same pressure. pulled 104 feet. dont think i could pull 3rd on a track that is sticky
pretty happy actually, beat a few 600 hp duramax's the second time around. clearly it was all about traction this weekend and whoever didnt have it, did not do well.
ive got some videos I can post.. will do later
Re: can i pull?
Postby ahale2772 » Mon Jul 23, 2012 9:17 am
second pull, had all the power/wheel speed, just not enough traction.
19.5's will good tread in theback, brand new general grabbers up front, 265/75/16
Return to Competition
