WILL MY NEW COMBO WORK?? PUMP TURBO???
Re: WILL MY NEW COMBO WORK?? PUMP TURBO???
Postby soggy » Fri Jul 20, 2012 8:08 am
You have something way off, I have the same size turbo and injectors and am running high 40s boost and about 1500 max egts with a 12mm. I'd check for boost leaks also.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby JQmile » Fri Jul 20, 2012 10:40 am
I would say somewhere around 25-30 deg. What kind of pistons do you have? Large bowl non-ic design, or the later smaller bowl ones?
JQmile
Postby agcododge » Sat Jul 21, 2012 3:25 pm
2nd gen pistons and injector tips,, flycuts 14.1 compression
agcododge
Postby agcododge » Sat Jul 21, 2012 3:28 pm
I had timing marks all lined up the advanced the pump which i dont think is much..Maybe i need to turn the gear a tooth. Not sure what timing advance externally fully is..??
agcododge
Postby AHineman » Sat Jul 21, 2012 3:57 pm
I think pump to the head is in the neighborhood of 20-22 degrees. Each tooth is 10 degrees. Turn gear clockwise to advance.
Postby agcododge » Sat Jul 21, 2012 4:10 pm
ok....i will confirm im fully advanced and open it back up to turn gear.. Thanks
agcododge
Postby JQmile » Sun Jul 22, 2012 6:55 pm
Mine jumped a tooth and about 1/2 way to the head is 27deg on a timing light, so that should sort of give you a place to start.
JQmile
Postby agcododge » Sun Jul 22, 2012 9:19 pm
JQmile wrote:Mine jumped a tooth and about 1/2 way to the head is 27deg on a timing light, so that should sort of give you a place to start.
Do u think i could stand for bigger injectors?? Scheid told me 5x18s is as big as i dare go.. I see ur profile is 5x25.. Adding water/meth this week and would like to learn a little about some nitrous for the next step..
Thanks
agcododge
Postby oldestof11 » Mon Jul 23, 2012 2:09 pm
You can if you want. However, are you cleaning up the exhaust smoke? If not, the a bigger injector wont help.
A video would help.
Postby JQmile » Mon Jul 23, 2012 3:56 pm
Thanks
I'd say with 2300 deg EGT you have way too much fuel already. You need to figure out how to get more air into the engine! Nitrous will definitely help, although I thought you pullers were more the "fuel only" crowd.
JQmile
Postby agcododge » Mon Jul 23, 2012 6:02 pm
The smoke does clear up...very clear..
agcododge
Postby agcododge » Mon Jul 23, 2012 6:03 pm
Half my pulls are open OPEN..Run what you have.. So the diesel/water is only at 6 or so events
agcododge
Postby agcododge » Mon Jul 23, 2012 6:05 pm
Thanks
So to confirm my timing----When im looking at the timing gear i turn it CLOCKWISE to advance?? Thanks
agcododge
Postby AHineman » Mon Jul 23, 2012 6:19 pm
agcododge wrote:So to confirm my timing----When im looking at the timing gear i turn it CLOCKWISE to advance?? Thanks
AHineman wrote:Turn gear clockwise to advance.
8)
Postby agcododge » Mon Jul 23, 2012 6:20 pm
8)
Thanks....
agcododge
Return to Competition
