traction bars
traction bars
Postby jacobwebb57 » Sun Jul 22, 2012 9:08 am
im looking to make a set of traction bars... just wondering how you guys are doing them what your setup are like and what parts ill need....i work at a metal fab shop so getting the stuff is no problem...thanks
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: traction bars
Postby oldestof11 » Sun Jul 22, 2012 2:49 pm
Quick and "cheaper" is 2 sets of tractor top links with some 2" poop pipe (black iron).
Otherwise 2 left and 2 right handed hiems and some DOM tubing.
What is the purpose of the truck? General play, racing, puller?
If the 1st 2, shackle flip on the rear (eliminate the lift block) and Caltracs.
Otherwise traction bars in a ladder type setup (2 bars, 1 on top and 1 on bottom of the axle tube, connected before front hook-up point) is a good setup.
Re: traction bars
Postby jacobwebb57 » Sun Jul 22, 2012 3:17 pm
i tow a 26 ft goose neck camper. and ill pull it probably 2 or 3 times a year..other then that its just for play
jacobwebb57
Re: traction bars
Postby redneckroot » Mon Jul 23, 2012 8:55 pm
I have the tractor top link set up on my truck, I wouldn't use them for one I planned on driving on the road again. They tend to loosen up over time and rattle. This winter mine are getting replaced with some from these guys http://www.ruffstuffspecialties.com/cat ... DENDS.html
Not the cheapest out there but the rattle drives me nuts. My bars have worked great and don't bind at all. They are roughly 7 feet long. I built my mounts on the rear end so I could run a double ladder style if I wanted to but I haven't had a problem yet.
redneckroot
Re: traction bars
Postby Hansen01 » Tue Jul 24, 2012 1:08 pm
I just ordered mine from this site, yea they are exspensive, but on the bright side they shipped to my door in three days :D
Under construction...
Hansen01
Re: traction bars
Postby ahale2772 » Tue Jul 24, 2012 3:03 pm
ruff stuff is pretty inexpensive... try and get the same quality rod end from Mcmaster or something
mine are ruff stuff heims, sleeved tubing, and a better corssmember to attach to
Re: traction bars
Postby redneckroot » Wed Jul 25, 2012 2:03 pm
I meant they aren't cheap compared to using top links.
redneckroot
Return to Competition
Users browsing this forum: No registered users and 75 guests
