1stgen pulling thread
Postby pulltilbroke » Fri Aug 03, 2012 1:16 am
Figured we could use a thread like this so we don't clutter up other peoples threads with pull results and what not.
Hooked mine again tonight, Woulda ended up 2nd but had a little carnage and got DQd for puttin pars on the track. Tonight I was running bars blocks and hangin weights. It was a short tack and they had the sled set Heavy.
Even though we tore it up and got DQd I am very pleased with how it ran. I put 15ft on the guy behind me and was only 6ft off the leader when she broke. I think I coulda got the winner but..........
Re: 1stgen pulling thread
Postby ahale2772 » Fri Aug 03, 2012 7:05 am
gona throw a stock shaft back in or upgrade?
Postby Hansen01 » Fri Aug 03, 2012 11:11 am
You need my bald tires so you can't break stuff, il sell em to you real cheap :lol:
Under construction...
Hansen01
Postby pulltilbroke » Fri Aug 03, 2012 12:35 pm
Probably shoulda had my half bald StSs on the back. I know one thing BFG ats are my new tire of choice for pulling.
Oh and i alredy got another shaft in and its ready to hook again tomorow.
Postby ahale2772 » Fri Aug 03, 2012 3:09 pm
stock shaft or better?
Bfg's over STS?
Postby dazedandconfused » Fri Aug 03, 2012 3:13 pm
You cant beat BFG's for pulling on most tracks.
Postby oldestof11 » Fri Aug 03, 2012 7:57 pm
Yep. All the big dogs seem to run BFGs AT. My newer set of tires are a little more aggressive than that.
Andrew, I wish they hhad a class I could hang weights in. Would make it a little more fun.
Postby ahale2772 » Fri Aug 03, 2012 8:11 pm
Ive got a local track that most guys swear by sts's, but its a loose track.
funny how the AT's find a new niche even after being around for a lonnnggg time
thinking of trying some from these guys... the 94 needs tires, might run these on the drive tires, regular BFG's on the front
https://www.treadwright.com/p-59-265-75 ... a-t-e.aspx
Postby pulltilbroke » Sat Aug 04, 2012 12:43 am
Postby oldestof11 » Sat Aug 04, 2012 3:14 am
Gonna make yourself some driveshaft loops?
Postby pulltilbroke » Sun Aug 05, 2012 8:59 pm
Yeah I need to start fabbing some up.
Anywho here is the whole class from Thursday night.
http://www.youtube.com/watch?v=caVzgPrCyBc&feature=plcp
Well I hooked it 2 times last night and ended up 4th in both the Light and heavy 2.6 Classes. I'm still working on those videos though.
Postby oldestof11 » Mon Aug 06, 2012 2:06 pm
Mine are 3/4" or 7/8" U-bolts bolted to the skid plate and a cross member halfway between the axles and the cab.
Postby Hansen01 » Mon Aug 06, 2012 9:02 pm
Looked like your suspension setup worked well that night, at least alot better than some of the other times. I was sitting up in the stands with my girlfriend and Danny McCullock (welding teacher in Lincoln, He said he knew you and was tellin us storys about you, :lol:
Hansen01
Postby pulltilbroke » Mon Aug 06, 2012 10:43 pm
Yeah I went back to the old setup. Bounced out of the hole though.
Dannys a good guy, Been a while since I seen him.
Postby pulltilbroke » Mon Aug 06, 2012 11:16 pm
Return to Competition
