1stgen pulling thread
Re: 1stgen pulling thread
Postby oldestof11 » Tue Aug 07, 2012 6:11 pm
Very nice!
Postby Hansen01 » Tue Aug 07, 2012 7:56 pm
Got em 8)
Under construction...
Hansen01
Postby redneckroot » Tue Aug 07, 2012 9:51 pm
Glad to see the 1st gens back out hooking.
redneckroot
Postby pulltilbroke » Sun Aug 12, 2012 10:11 pm
Postby redneckroot » Mon Aug 13, 2012 5:47 pm
Nice hook!
redneckroot
Postby pulltilbroke » Sun Aug 19, 2012 12:51 pm
Welp really been livin up to my screenname this year.
Really tore it up good last night. Broke a traction bar frame mount which caused the axle to wrap up severly which in turn broke both spring perches on the axle, then with the crazy pinion angle it spit the shaft out when it ripped the straps off the yoke, it also broke both spring center pins and bent some u bolts.
However I ended up with a 3rd and a 2nd
Postby PToombs » Sun Aug 19, 2012 5:26 pm
How cool is that! :lol: Did you twist the axle back and drive it home on the front shaft?
Postby dazedandconfused » Sun Aug 19, 2012 5:47 pm
Now that was a biting track by the looks of it.
Postby pulltilbroke » Sun Aug 19, 2012 6:06 pm
Didn't even twist it back down, Pulled the bars and the shaft, Unloaded the rack and pulled the blocks and drove it home dog trackin like a bitch.
Now we get to pull the whole axle out from under the truck and burn off the old perches and weld some new steel ones on, put a new yoke on, put 2 fresh joints in the shaft pull the springs and do new center pins.
Postby Hansen01 » Sun Aug 19, 2012 6:34 pm
Least you placed good :lol:
Someone get videos of that happening?
Hansen01
Postby pulltilbroke » Sun Aug 19, 2012 8:35 pm
Postby Hansen01 » Mon Aug 20, 2012 3:41 pm
:shock: should have had an onboard camera for all the words that came out of your mouth after that one,
I figured youd have it back together within a week or so :lol:
Be interesting to see how this Tekamah pull pans out entry wise,our rodeo ground people are horrible with advertising, but they arnt the ones who set this up so hopefully wel have a good turn out
Hansen01
Postby 1STGENFARMBOY » Thu Aug 30, 2012 2:12 pm
Andrew ..i guess your gonna make some traction bar brackets to weld on the axel tubs now eh.
what you had did a fine job of keeping the springs from rapping, but didn't keep the rearend from
trying to spin.
I would have never thought about that happing if i hadn't saw it happin to you. way to take one for the team.
Darwin
Postby KTA » Thu Aug 30, 2012 4:33 pm
While you are welding perches on you better weld the carrier to the axle tubes too! Trust me they will spin up next if you keep the axle in place and they are a BITCH to try to straighten out.
Postby pulltilbroke » Sun Sep 02, 2012 12:36 am
Well its back together now. And Brian I did weld the tubes to the pig.
When I ordered the perches I had em blow some extra spring pin holes so I could offset the axle back and gain an inch of wheelbase
Return to Competition
