Needing some help
Needing some help
Postby dgosney » Tue Feb 19, 2013 7:45 pm
Hey guys pulling season is coming up pretty quick and I'm in need of some more power. Last year I didn't do to well but i did beat some stock commonrails and powerstrokes. My truck is 6200lbs with 3.54 gears and 235s. I want enough power to run 3rd low. I have dap 5x.012s a hx40 a fass pump and one of kennys dual discs. What do I need for 3rd?
dgosney
Re: Needing some help
Postby Tacoclaw » Tue Feb 19, 2013 8:05 pm
Have you done most of the pump/throttle linkage/throttle cable mods to get as much RPM/fuel as you can out of it? Do you also have an open exhaust and some sort of decent intake system?
What is your full mod list?
You might just want to drop a tire size or something if it's feasible.
Postby dgosney » Tue Feb 19, 2013 8:14 pm
I have all the usual pump mods and it's got a 4 inch down pipe to the t-case and 5 inch from there. The intake is just a bhaf. I can't really drop tire size cause a 235 is pretty damn small and I don't think it would make enough of a difference
dgosney
Postby oldestof11 » Tue Feb 19, 2013 9:03 pm
You want a bigger tire. And until you get into the S300 turbos (62-66mm), I doubt you will get 3rd low and pull into peak torque.
Postby Hansen01 » Tue Feb 19, 2013 9:06 pm
3000-3200rpms works for me with 285's
what size exhaust housing on the 40? Down size the housing if you got a big one.
Under construction...
Hansen01
Postby Hansen01 » Tue Feb 19, 2013 9:08 pm
oldestof11 wrote:You want a bigger tire. And until you get into the S300 turbos (62-66mm), I doubt you will get 3rd low and pull into peak torque.
Its very possible, i could almost do it with mine when i had the 5 speed and stock sticks
Hansen01
Postby oldestof11 » Wed Feb 20, 2013 4:23 am
But the power it takes to turn 33's is not there. That is a gear almost like 4th and low on a 6 spd. I could almost do it but the power is not there to take you down the track.
Postby dgosney » Wed Feb 20, 2013 7:53 am
Wouldn't a bigger tire make it a faster gear? The 40 has a 16 housing and I have no problem staying on top of it. I just need to figure something out without blowing a bunch of money on parts I don't need because I'm sure that money will be spent on repairs if it will run like I want it. 2nd low just isn't any fun and i want to place better than 5th or 6th out of 10 everytime.
dgosney
Postby dgosney » Wed Feb 20, 2013 7:55 am
Oh and 3rd is like 4th low on a 2nd gen 5 speed with 4.10s
dgosney
Postby oldestof11 » Wed Feb 20, 2013 3:08 pm
Bigger has a faster final but more importantly, wider tread and contact patch which is more traction.
Postby dgosney » Wed Feb 20, 2013 3:46 pm
I have plenty of traction with 6 new all terrains. It's the horsepower that I'm lacking.
dgosney
Postby oldestof11 » Wed Feb 20, 2013 8:20 pm
You have a posi in the rear?
Postby dgosney » Thu Feb 21, 2013 7:15 pm
Yeah
dgosney
Return to Competition
