Traction bars on a '93 W250
Postby TRACTJDS0428 » Fri Apr 19, 2013 5:55 pm
Getting ready to build my traction bar set up for my truck. Looking at the rear axle, im gonna need longer U bolts. Does anybody know what size come on the truck off the top of their head or what size u bolts everybody is using for traction bars on the 1st gens? Do i need to box the frame where i mount the front?
1993 Dodge W250, Cold Air, Borg Warner 60/68 turbo. 4" down pipe. 5x14 Injectors. Pump Mods. Airdogg II 165, Billet Fuel Tank Sump. ATS valve body, ATS converter, Pyro, Fuel pressure, Boost and Trany temp gauges. 72" T-Rex Products Long Bars. 285/75-16 Toyo Open Country M/T's. Western 9Ft MVP Ultra Mount V-Plow.
TRACTJDS0428
Re: Traction bars on a '93 W250
Postby Hansen01 » Mon Apr 22, 2013 8:01 pm
When I did mine, we just welded the brackets to the rear end. Just another option for you
Under construction...
Hansen01
Postby TRACTJDS0428 » Tue Apr 23, 2013 4:56 pm
Did you weld them to the axle tube or to the u-bolt bracket?
TRACTJDS0428
Postby dweissenfluh » Tue Apr 23, 2013 11:29 pm
If it was me I would welt tabs to the axle tube and bolt my links to them.
dweissenfluh
Postby stillsmokin » Wed Apr 24, 2013 12:53 pm
Weld tabs to the axle tube for those bars, it might last a little while but pulltilbroke can show you what happens when the axle rotates in the plates. BANG!
92 W250LE REG CAB, SLED PULLER, S400
93 W350LE EXT CAB, dually, 5 speed
stillsmokin
Postby Tacoclaw » Wed Apr 24, 2013 3:42 pm
They're 1/2" fine thread, can't think of the exact thread TPI, 28 I think.
Just whip out a tape measure and get the length of the legs and whether it's a round bend or a squared off bend. It's squared off I think, on a 2.5" wide leaf. Any spring shop can whip them up for you in no time, I think mine ran me like $30 for all four.
Also make sure you have them put enough thread on the legs.
Postby TRACTJDS0428 » Wed Apr 24, 2013 6:03 pm
Ok so i have a place down the road that can get me the u-bolts. but what are the pros and cons to welding to the axle housing? I know that the axle can rotate under the right circumstances but what kind of problems could i have welding directly to the axle? I am a welder so i know i have to be careful not to damage bearings. Im thinking geometry could be a little more difficult. Does anyone have pictures of their setup? or can someone point me in the direction of pictures?
TRACTJDS0428
Return to Competition
