guess my hp
guess my hp
Postby turboram » Mon May 13, 2013 10:33 am
Gonna take my truck to the dyno .Heres my setup 24v, ported head,cam, low compression on 2 cylinders ,2.5 pulling turbo,6x13 flow honed injectors ,and oh yah 14mm ve. Wager away
turboram
Re: guess my hp
Postby Sutter1stgen » Mon May 13, 2013 11:10 am
Are you running your dual feed???
If not I'll guess 550-600 with 2x torque figures.
Eric
Sutter1stgen
Re: guess my hp
Postby Tacoclaw » Mon May 13, 2013 12:25 pm
Re: guess my hp
Postby RCCUMMINS89 » Mon May 13, 2013 12:31 pm
532/1138
Re: guess my hp
Postby dazedandconfused » Mon May 13, 2013 1:20 pm
650/1250 if dual feed keeps the pump fueled like on your test stand. We need video to.
Re: guess my hp
Postby 1STGENFARMBOY » Mon May 13, 2013 2:35 pm
490....
Re: guess my hp
Postby turboram » Mon May 13, 2013 4:51 pm
At least most of the numbers are realistic. Maybe wedsday Ill have some numbers. I expect low because this dyno is nicknamed the disapointer .. they had a compound turbo commonrail on there and it only made 780HP
turboram
Re: guess my hp
Postby RCCUMMINS89 » Mon May 13, 2013 5:44 pm
What's your guess?
Re: guess my hp
Postby oldestof11 » Mon May 13, 2013 7:23 pm
load or inertia dyno? Makes a difference. If inertia, run in OD.
Load: 625 HP
Inertia: 375 HP
Re: guess my hp
Postby turboram » Mon May 13, 2013 8:13 pm
The truck made more than 500 on an inertia dyno with the vp..... it is however going to a load dyno, then back to the inertia next week. I would hope for 600hp but if it doesnt make 500hp i'll admit defeat
turboram
Re: guess my hp
Postby Sutter1stgen » Mon May 13, 2013 8:20 pm
oldestof11 wrote:load or inertia dyno? Makes a difference. If inertia, run in OD.
Load: 625 HP
Inertia: 375 HP
I've often wondered if I should run my truck in o/d. It originally didn't come with o/d, and has 3.07 gears. So I always leave it in D. That way my control group is the same. Do you think I'll gain anything running it in o/d??? Probaly torque at least.
Eric
Sutter1stgen
Re: guess my hp
Postby dweissenfluh » Sat May 18, 2013 10:37 am
Tacoclaw wrote:Image
Hahahahahhaa ! what he said!
dweissenfluh
Re: guess my hp
Postby turboram » Tue May 21, 2013 4:38 pm
Looks like this Friday is the day
turboram
Re: guess my hp
Postby turboram » Fri May 24, 2013 6:04 pm
609 hp and 1088tq was the number..... with a good motor it should be about 50 hp higher
turboram
Re: guess my hp
Postby PToombs » Fri May 24, 2013 6:09 pm
Sutters 1st guess was closest, he gets an all expenses paid (by him) trip to someplace where he can drink beer and brag about it! 8)
Congrats Sutter1stgen!
Return to Competition
