Hit the dyno
Re: Hit the dyno
Postby The_Head » Sun Dec 01, 2013 3:20 pm
It's in the stock position with respect to the head.
The_Head
Re: Hit the dyno
Postby RCCUMMINS89 » Sun Dec 01, 2013 3:33 pm
Back it off about 1/4".... Now, if it is like my set up...you'll find that it will increase smoke when tipping into the throttle though. But it will greatly help with spoolup. I bet it'll give you 2-5 more psi when chugging down the road and hitting small inclines.
Re: Hit the dyno
Postby Sutter1stgen » Sun Dec 01, 2013 11:15 pm
Timing can make a huge difference. I tried spooling at the line with my ksb on, and what a joke that was. 10 seconds to spool is no bs. The other morning while doing some testing in 4wd I decided to try spooling with my ksb off. Wow!!!!!! What a difference that made. We are talking near stock spool up. Time for me to rig a pressure switch up on my ksb.
Eric
Sutter1stgen
Re: Hit the dyno
Postby skilletky » Mon Dec 02, 2013 10:22 am
Sutter1stgen wrote: Time for me to rig a pressure switch up on my ksb.
it works awesmome!!! had mine set to come on at around 10 to 15 psi.
skilletky
Re: Hit the dyno
Postby RCCUMMINS89 » Mon Dec 02, 2013 10:53 am
Ya, I'm thinking about adding my ksb to my adjustable timing spacer so that I can do it in the high rpms.
I got the idea from someone else.....and it is a good idea.
Re: Hit the dyno
Postby Sutter1stgen » Mon Dec 02, 2013 11:04 am
You as well as a few others have told me about this before. It's just that I've been fighting other gremlins!!!
But I hoe to get this truck dialed in a little better. Did you ever mess around with different pressure switches?? Like 15,20,25 psi.
Eric
Sutter1stgen
Re: Hit the dyno
Postby AHineman » Mon Dec 02, 2013 8:12 pm
I've never messed with different pressures, but mine seems to work well coming on at 20 psi. That is where mine starts cooking anyways. :lol:
Re: Hit the dyno
Postby Sutter1stgen » Tue Dec 03, 2013 8:04 am
Thank you sir!! I went to my local napa a while ago, and it was in the back of my mind. Stayed there too. I'll grab a 20psi switch next time I'm in there.
Eric
Sutter1stgen
Re: Hit the dyno
Postby AHineman » Tue Dec 03, 2013 12:09 pm
When I get home I'll get a part # for you. Certain ones have a crazy dead band or don't work at the correct pressures.
Re: Hit the dyno
Postby Sutter1stgen » Tue Dec 03, 2013 1:33 pm
Thank you.
Eric
Sutter1stgen
Re: Hit the dyno
Postby Tacoclaw » Tue Dec 03, 2013 2:23 pm
AHineman wrote:
BC847 wrote:I'm thinking of rigging a boost activated adjustable pressure switch that will illuminate a dash mounted light when I get to . . . . say . . . 20psig.
Napa 701-1575 is the pressure switch I've got to activate my KSB at 20psi of boost. 20psi is about the max for it to consistently make and break. They make some that work for higher pressures, but the dead bands are bigger than I would like. I had mine on a Druck at work and it was changing states at 19.3-19.7 psi.
It is adjustable. Pop the rubber cap off the end and there is an adjustment screw.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=BK_7011575_0361175264
You may find something that would suit you better on Napa's website, I had no luck at the store. They didn't even know they sold them until I gave them a part number. :lol:
Re: Hit the dyno
Postby AHineman » Tue Dec 03, 2013 2:43 pm
Thanks buddy. I didn't have time at work to mess with all that today.
Like I said in that post, 20 psi is about the max setting on that one, but it is consistent and has very little deadband.
Re: Hit the dyno
Postby Tacoclaw » Tue Dec 03, 2013 3:40 pm
I looked it up at work, sounds like you're just not working hard enough. :P
Re: Hit the dyno
Postby Sutter1stgen » Tue Dec 03, 2013 5:21 pm
Awesome! Thanks guys.
Eric
Sutter1stgen
Return to Competition
