Off to the dyno
Off to the dyno
Postby VanillaGorilla » Mon May 05, 2014 3:30 pm
Curious on what you guys think I might make. 93 W250, built trans and a lower stall converter, Non IC pump that's basically maxed and has been ported out, 3200 spring, timing bumped, Denny T stage 2 pin, BD super B turbo, BD 40hp injectors, 60# springs, 4" exhaust, Holley 110gph lift pump and -8 fuel lines. The only thing that may change is a 3800 spring. What are your thoughts? I am hoping to see 400hp but really not sure, thanks
93 Reg cab LE 4x4 518AT, 145k and counting, pump turned up,Internal pump mods, Denny T stage 2, non IC DV's, timing bumped up, BD 40hp injectors,BHAF and me-built mandrel bent CAI,4" turbo back, Holley lift pump, new white with gold paint job, recieving more mods to tow the Duster and push this stupid WI snow.
VanillaGorilla
Re: Off to the dyno
Postby fatty » Mon May 05, 2014 7:01 pm
350-375 is my guess. When are you dynoing?
Re: Off to the dyno
Postby VanillaGorilla » Mon May 05, 2014 8:22 pm
The 24th, just need to call and make sure he has an optical pick up or it's not worth my time/money
VanillaGorilla
Re: Off to the dyno
Postby VanillaGorilla » Thu May 08, 2014 4:36 am
Damn, one guy has a guess...
VanillaGorilla
Re: Off to the dyno
Postby ellis93 » Thu May 08, 2014 5:54 am
Seeing as I slept in a holiday inn express last night I'll play. :)
345hp
Re: Off to the dyno
Postby RumbleFish » Thu May 08, 2014 5:58 am
Are we playing by the price is right rules? $1Bob.
Re: Off to the dyno
Postby ellis93 » Thu May 08, 2014 7:13 am
RumbleFish wrote:Are we playing by the price is right rules? $1Bob.
That's what I was doing :lol:
Re: Off to the dyno
Postby VanillaGorilla » Thu May 08, 2014 8:35 am
ellis93 wrote:Seeing as I slept in a holiday inn express last night I'll play. :)
345hp
Thanks. Like I said hoping to be around 400 but I kind of think the injectors are holding it back. I'm open to suggestions fellas, truck also tows so max power isn't the main concern
VanillaGorilla
Re: Off to the dyno
Postby BC847 » Thu May 08, 2014 8:41 am
300 ~ 350. :)
Re: Off to the dyno
Postby ellis93 » Thu May 08, 2014 8:53 am
345hp
In all seriousness, and from what I've seen in the forum reading I've done,I bet it's either what I guessed or a little lower. Like you said,it'll be all about the injector size.
Again tho I have no real world experience :lol:
Re: Off to the dyno
Postby RCCUMMINS89 » Thu May 08, 2014 9:05 am
Super B are great turbos, but they don't normally peak the dyno very high. Without knowing the size of your injectors.... (though I think I know approx. what size they are) it is actually your turbo that is probably holding you back.
An he51cw has on multiple occasions peaked 400+, but barely. A super b flows roughly 60-61#/min, where as an he351cw flows 68#/min. The super b is a far superior towing turbo though.
Re: Off to the dyno
Postby VanillaGorilla » Thu May 08, 2014 5:23 pm
RCCUMMINS89 wrote:Super B are great turbos, but they don't normally peak the dyno very high. Without knowing the size of your injectors.... (though I think I know approx. what size they are) it is actually your turbo that is probably holding you back.
I can't argue facts, towing is the main concern so until I have another truck for working this thing will make what it makes haha. Can I ask what size you think these injectors are?? I bought them used on here when my stock ones went, I couldn't find any good info on them. Thanks, can I ask opinions on a set of 5x12's? From my reading they seem like a good addition to the truck
VanillaGorilla
Re: Off to the dyno
Postby RCCUMMINS89 » Thu May 08, 2014 6:32 pm
I THINK the +40s are around a 50lpm size (just shy of a 5x12)
Re: Off to the dyno
Postby VanillaGorilla » Thu May 08, 2014 7:08 pm
RCCUMMINS89 wrote:I THINK the +40s are around a 50lpm size (just shy of a 5x12)
So if this is correct a 5x12 may not be a great upgrade?
My main problem with these is the ridiculous haze at idle
VanillaGorilla
Re: Off to the dyno
Postby RCCUMMINS89 » Thu May 08, 2014 9:11 pm
If they are a 4 hole injector, they are the wrong spray angle.... why wouldn't you think a 5x12 would be a good upgrade? Are you looking for a lot more fuel, or just a little?
Return to Competition
