Want to do some Drag Racing
Re: Want to do some Drag Racing
Postby draginmopars » Tue Oct 20, 2015 7:34 am
should I get a 4200 spring
since, i'll be grinding the valves , new seals and changing springs
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby RCCUMMINS89 » Tue Oct 20, 2015 10:53 pm
You'll want an upgraded lift pump. I use our piston lift pump upgrade on all builds we put together.
Postby draginmopars » Fri Nov 06, 2015 6:36 pm
Everything even fits , with the hood on...
I have the original steel / flat hood
I may put back on ( gray primer color)
Bill helped put the front clip on
Not heavy> just flimsy
Then I realized a mistake
the engine is set back 16", instead of 12" I had thought
I should say the transmission mount is set back 16" from the original location.
I used the trans mount to locate the eng/trans front to back
Bill also says I have a loose wire> putting a Cummins in the Satellite
as he points to the Block heater plug, hangin off the front of the grill LOL
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby dazedandconfused » Sat Nov 07, 2015 2:25 pm
It fits well in there. I'd run a 3.07 or similar rear gear and let the torque carry you off the line. Your going to run out of power with a deep gear and the 272
Postby draginmopars » Wed Aug 17, 2016 8:51 am
Finally took the Satellite to the track
Never had so much fun
Going so Slow.....lol
It leaves quicker than I thought it would
started at 5 lbs boost
fourth run
finally figured out the lights
and how deep to stage
Now That I got a base # to work with
Time to crank it up...lol
next is Gear change> turn the pump up, gov spring, valve springs
https://www.youtube.com/watch?v=RxrriOfjYAY
https://www.youtube.com/watch?v=oIqB9TK3E5Q
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby Farmboy » Thu Aug 18, 2016 4:29 am
That's just plain cool!
Farmboy
Postby draginmopars » Thu Sep 22, 2016 5:21 pm
pulled the Dana
put a 8 3/4 with a 3.55 in Temporary
went to the track again
still only made 3/4 track before running out of steam
last Friday night
first 2 passes, I don't know what I was thinking
only let engine get to 160* > used to the Dart on E-85
next 3 passes got temp to 180*
Tuesday night
using a blue holly pump, turned up to 10psi
removed the power screw collar, turn screw in
installed 3800 gov spring
bumped the pump another 1/8 toward the head, plus has skipped a tooth
results > looks like to much timing
slower 60ft and ET
MPH was better due to 3800 spring
interesting 2 passes
Friday night on the left
Tuesday night on the right
Next is back the timing back to where it was.
set up gears for the Dana and re-install
Sit next to the mail box> waiting on a HE351CW turbo to fall off the UPS truck
also looking for some 5 x 12 injectors
and saving my pennies for a modified injection pump> more flow
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby dazedandconfused » Thu Sep 22, 2016 5:27 pm
Looking good. What gears are you going with?
Postby draginmopars » Thu Sep 22, 2016 5:40 pm
dazedandconfused wrote:Looking good. What gears are you going with?
being I only run 1/8 mile
3.73 see how they do>also have a 3.54 set
the Tuesday night passes engine really started to pull hard, but finish line came up...
will be a few weeks before I run it again
first install turbo
while doing that install 60 lbs springs, and 5 x 12 injectors
right now trying to find info>>
If I should locate 10* keepers and retainers, since I've already installed the 3800 spring
My "Gasser" brain says YES
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Thu Oct 06, 2016 6:31 pm
Sourced a few more parts
Built a new air horn and flange
old> 1.700"
New > 3.00"
Hope to have Twice as much fun > 351 turbo VS stock
laid out a plan
3" cold side
4" exhaust
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Fri Oct 07, 2016 8:46 pm
got it trimmed down to fit
even got the air box mounted
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby dazedandconfused » Sat Oct 08, 2016 5:54 am
It's looking really good.
Postby 79Powerwagon » Sat Oct 08, 2016 4:45 pm
Looks like a lot of fun.
Airbox is probably a choke point, AFE makes one hell of a dry filter.
79Powerwagon
Postby draginmopars » Sat Oct 08, 2016 5:16 pm
79Powerwagon wrote:Looks like a lot of fun.
plan is to open up the box,
Once I see where to secure it to the fender
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Wed Oct 19, 2016 1:10 pm
had "FUN" tonight
Didn't break anything....
forgot to retard the timing, and turn up the power screw.> didn't bring any tools...
ran good considering stock injectors
https://www.youtube.com/watch?v=R2hRob-jgnQ
https://www.youtube.com/watch?v=a5K_rrJ3m0Y
interesting comparing times from last week before the turbo and valve spring change.
also was 8 3/4.... 3.55 gear, now Dana 3.73
Tonight
last week
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Return to Competition
