6 seconds
6 seconds
Postby DTanklage » Thu May 22, 2008 11:07 am
first diesel in the 6's
they did it with a 358 cu in cummins
DTanklage
Postby burnt_servo » Thu May 22, 2008 11:42 am
the 358 , is that the same engine as a 5.9 or a entirely different animal ?
'93 w250 .... stock ...
burnt_servo
Postby 89silverbullet » Thu May 22, 2008 6:14 pm
it is the same beast if im not mistaken. 5 liters is 300 cubic inches so 60 inches to a liter 5.9x60=354 with my red neck math so give or take 5 cubic inches :2cool:
1989 d250 muffler delete diaphram turned, fuel screw turned, the lowes special intake
89silverbullet
Postby JAyers » Fri May 23, 2008 11:39 am
359 cubes....is what a stock one should be.
93 W250...balanced, ported, and fresh. Equipped with 14mm h/r, A1000 supply, Hamitons 188/220, T4 stainless manifold, s360/68/.91ar - s475/74/1.1ar twins, and Kennys dd clutch.
JAyers
Postby Begle1 » Fri May 23, 2008 2:20 pm
I read that 5.9 liters are really only 5.88 liters anyways... :lol:
Postby GO OVRIT » Fri May 23, 2008 4:16 pm
....and 300 ci is 4.9 liters :grin:
GO OVRIT
Postby 89silverbullet » Sun May 25, 2008 11:14 pm
smart ass :)
89silverbullet
Postby VEfreak » Thu May 29, 2008 7:40 pm
next we can hit five seconds and then over power top alcohol.
VEfreak
Postby DTanklage » Tue Jul 15, 2008 10:04 am
and thus the 358 cu in
or is that not correct?
talking new motor
not one with a bunch of miles on it
tank
DTanklage
Postby SChandler » Tue Jul 15, 2008 12:07 pm
For a stock bore/stroke (4.02"/4.72", respectively) motor the math works out like this: 3.1416 x 4.02^2 x 4.72 / 4 x 6 = 359.447 cu. in. Cummins calls it a 359, Dodge calls it a 360 and we all call it a 5.9 :lol: .
Edit: If you do the same calculations in metric (bore = 102.1mm and stroke = 119.9 mm) you get 5.89 liters.
SChandler
Postby DTanklage » Tue Jul 15, 2008 1:07 pm
SChandler wrote:
...and we all call it a 5.9
not all of us . . .
i still call mine a 358
(destroked it a little bit ya see)
DTanklage
Return to Competition
