good day in the rain
Postby seeker1056 » Mon Jul 21, 2008 5:13 am
well we took the ol truck out on Sunday to the pulls.
Even with my daughters bf as a rookie driver it made fifth place in the mud - as it hadrained all day and only let up long enough to get the pull in.
was only a couple feet between first and fifth
Got beat by a pp truck a couple chipped truckes and a Ford that was chipped
Still need more tire - hit second gear at about a hundred feet and blew the tires out from under it just as soon as boost hit 45 lbs
:lol: ;)
oh and this is on last years setup as I havnt had time to put any of the new equipment listed in my signature on the truck except the 6x18's
All in all a good day
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Stomp » Wed Jul 23, 2008 11:14 pm
Congrats on the pull. I know you will get it figured out and when you do look out, because I am sure that it is going to pull like no other. I am glad you are sticking with the VE pump.
Stomp
93W250CTD,7 isspro gauges,Piers stage 2+ ported/polished/o-ringed head,ARP 12mm studs,ATS 3 piece,Custom twins by Brad @ Ponci's Diesel Center BTH3B/26 w/Piers HX40/16, custom 4"exhaust/ intake by Brad@ PDC,370's,KTA-Special 14mm Head/Rotor
Stomp
Postby cummins king » Thu Jul 24, 2008 1:34 pm
hey thats awsome ken
are you planning on making it to the fergus truck show
Joel
93 4X4 auto
cummins king
Postby seeker1056 » Sun Jul 27, 2008 5:10 am
Nah we went to Lakefield - home boys over strangers right
Got third after twistin up the drive shaft like a pretzel at 290 ft - man the truck was smokin - coasted almost 5' after it broke - you couldnt peel the grin off the driver if ya tried
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby SChandler » Sun Jul 27, 2008 3:21 pm
seeker1056 wrote:Nah we went to Lakefield - home boys over strangers right
Did you ever get your drive pressure issues fixed? 295' is awesome. Sounds like the 6x18's are working well. How's the converter in your C6 holding up?
SChandler
Postby seeker1056 » Sun Jul 27, 2008 5:14 pm
no I havnt had time to do anythng with the truck, so 48 psi boost n about 60 psi drive pressure - but if I have time this week putting a big single on so I can compete in Pro Street for the rest of the season.
I will get all the pieces I have accummulated that are in my signature, installed this winter, and put the big twins on the n make a dyno run n see what I can do.
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby SChandler » Sun Jul 27, 2008 6:44 pm
I'm curious to hear how a big single runs on a VE-pumped truck in a sled pulling app. Since the VE is rpm limited, it seems like it would be hard to keep a big single lit. Good luck and let us know how it works.
SChandler
Return to Competition
