S300 down pipe
S300 down pipe
Postby redneckroot » Thu Aug 14, 2008 8:27 pm
For a s300 what down pipe do i need? the same one as a hx40? I want atleast a 4" Any help or webpages would be great thanks guys
redneckroot
Postby SChandler » Fri Aug 15, 2008 4:53 pm
It depends on the flange on the turbine housing. The aftermarket S300's designed for the Dodge/Cummins application typically have an HX40 style flange. There is also a S300 specific flange from what I've read. Plus, I think that there is also an aftermarket 3rd Gen Dodge/Cummins flange. You'll need whichever one matches your turbo.
SChandler
Postby fergavs » Fri Aug 15, 2008 6:33 pm
Our trucks are simple to build downpipes for. As stated above most cummins specific s300's use the hx40 downpipe. All you need is two pre bent mandrel 90's (big rig truck exaust is cheap) and a straight section about 30" long. As far as the flange goes they can be ordered online or if you have a plasma or torch just trace the output on the turbine and cut one outa plate. I think they are normally about 1/4" thick. Just cut out a ring, clean it up with a grinder, and weld it to your mandrel 90. Attach the straight section then the other 90 and BAM 4" down pipe.
fergavs
Postby Richie O » Fri Aug 15, 2008 9:09 pm
My S300g has the hx 40 flange..
Postby redneckroot » Fri Aug 15, 2008 11:24 pm
I didn't realize there were different ones. How can you tell by looking at it?
redneckroot
Postby SNOOT » Mon Sep 15, 2008 11:24 am
Here is a picture of a 4" v-band down pipe DDP makes.. JFYI It uses a HX-40 flange.
Includes pipe and flange you have to weld the flange to the pipe during fitting.
This is a one piece unit and it fit like a glove.
1993 W350
SNOOT
Postby redneckroot » Mon Sep 15, 2008 8:29 pm
Great pictures thanks!
redneckroot
Return to Competition
