Passing tech with no emergency brake?
Postby Begle1 » Mon Sep 01, 2008 7:46 pm
Has anybody ever had their emergency brake checked when going through tech inspection at the drags?
Does anybody know if the rules stipulate an emergency brake?
Because I just snapped an e-brake cable, and it was only a couple years old too... And if I go to disks, it's a lot easier to go to disks without emergency brake provisions.
Postby RumbleFish » Tue Sep 02, 2008 6:13 am
tech at my local strip consists of seeing if there is enough windows to write your number on. i think they mainly check for safety issues, such as battery hold downs, throttle return springs, extended lug studs if you're on slicks, etc. i doubt they will care if your ebrake works or not, especially with an auto.
Postby sdstriper » Tue Sep 02, 2008 2:15 pm
How about you call them and find out? :shock:
sdstriper
Postby mprmn08 » Tue Sep 02, 2008 3:44 pm
i've dragged multiple vehicles and they have never checked the e brake. its not mandatory. theres no point to have a e brake on a track unless your drifting or something.
mprmn08
Postby Richie O » Tue Sep 02, 2008 4:02 pm
I got failed once for no nuetral safty switch. Once for no overflow tank ( that makes sense ). A buddy of mine got failed because he only had 2 lug nuts one his wheels... Still laughing about that. :lol:
Postby mprmn08 » Wed Sep 03, 2008 9:17 am
those are at least all legitimate things to not pass. serioulsy 2 lug nuts? and driving it on the road even still? nuetral safety is just so u dont bump it over in the lanes and hit someone.
mprmn08
Postby Richie O » Wed Sep 03, 2008 6:11 pm
mprmn08 wrote:those are at least all legitimate things to not pass. serioulsy 2 lug nuts? and driving it on the road even still? nuetral safety is just so u dont bump it over in the lanes and hit someone.
I agree. All those things make sense. By the way his wheel came loose on the way home. :lol: When I went to diesel weekend at my local track he looked under the truck for leaks and to make sure nothing was falling out. He looked under the hood for overflow tank and other obvious issues. Took him about 45 seconds to a minute and I was all set.
Postby 89silverbullet » Fri Oct 03, 2008 1:05 am
here in texas, if it can get to the track it can go 1/4 mile further. the inspection is small to just writing on the window as you drive by. They failed me because I had no turn down or up pipe. :cry:
1989 d250 muffler delete diaphram turned, fuel screw turned, the lowes special intake
89silverbullet
Return to Competition
