Industrial Injection Turbo?
Postby ryanihf250 » Thu Sep 18, 2008 2:27 am
Has anyone tried Industrial Injection Turbo on there 1st Gen. I am thinking about the phat shaft 66 for the street pull truck now. Wonder what modifications would be needed to install it besides the HX-40 downpipe.
Playtoy:1992 Dodge 350 4x4 SRW Cummins. 6in lift, 35in Pro Comp X , Dana 80 swap 4:10 Pump maxed, BHAF, 6x16inj, 3200 GSK, Piston Lift Pump, II SPS turbo.Street Pulling truck project. www.libertyantiquetractorpull.com
ryanihf250
Postby JAyers » Thu Sep 18, 2008 9:36 am
The down pipe is all that needs to be modified. I run a sps62 on my truck and i cant say a bad thing about it.
93 W250...balanced, ported, and fresh. Equipped with 14mm h/r, A1000 supply, Hamitons 188/220, T4 stainless manifold, s360/68/.91ar - s475/74/1.1ar twins, and Kennys dd clutch.
JAyers
Postby fergavs » Sat Sep 20, 2008 1:32 pm
I am running the BD Super B Special (64/71/14) and can spool it like a stock turbo or better. Aside from what JAyers mentioned you better have some custom EDM sticks and a 14mm h/r. I am trying to upgrade mine to a 66mm wheel so if it gets done I will post some results. I gotta say the 64mm turbo is AWSOME. I can spool it to the wategate setting (45psi) in about 1-2seconds and it sounds EVIL. :evil: My cruising EGT's are up 150deg to 800@65mph but my WOT playing EGT's are down. It is hard to compare because I did a lot of mods since my last turbo. (cam, edm sticks, IP, etc.)
fergavs
Postby ryanihf250 » Sun Sep 21, 2008 10:53 am
Appreciate the advice. I ordered the Industrial Injection Super Phat Shaft 66 on Thursday. All of it should be in on Thursday and we have a pull on Saturday to try it out. From what few of the distrubutors tell me I should have no problem spooling it with the 435's, NOS, and SB Pulling clutch. I didn't want to get a turbo that I will outgrow soon.
ryanihf250
Return to Competition
Users browsing this forum: No registered users and 69 guests
