VE+Big charger=This
Postby stillsmokin » Mon Oct 06, 2008 9:19 pm
bgilbert wrote:Sounds like you've got a plan with your build. Nice setup. You're right I should've just sat back and let you have your glory, then hear about how it worked or didn't work next season. It should give us SOP'er's something to talk about around the campfire though this year :lol: . That is since we haven't had any Stomp material to talk about for a couple years :shock: :lol: .
I'm not after glory, this is after all a science experiment. Heck, somebody has to try some different ideas once and a while. Those kind of ideas made guys like stomp and KTA stand out. If the new idea works the VE losses the term "power challenged" and that will be all the glory we need.
It's not about how much fuel you puke out the stack, rather it's about how much you can burn, and turn into torque applied to work.
Well, off to rest and then back in the shop before work, there's one more hook this year and I intend to at least try to scare a duramax owner or 2.
92 W250LE REG CAB, SLED PULLER, S400
93 W350LE EXT CAB, dually, 5 speed
stillsmokin
Postby dvst8r » Tue Oct 07, 2008 10:07 am
stillsmokin wrote:
dvst8r wrote:I very much could be wrong here and hope that I am, but every GT42 that I have pulled off a Detroit 60 (5 to this point, I have 3 right now), has had a 1.34T6 non gated housing, not an internal gate. As well has had the 70mm compressor that is found on the GT4294, not the 74mm found on the GT4202.
If some one could give me some insight as too which one's (years, or models or...) came with the GT4202 it would be much appreciated.
I have stared at these 3 gt42's for hours thinking about changing the turbine side and running one as a single, so this thread was good affirmation that it works. However I am still to chicken, and will just run it as is as a primary.
dvst8r,
I can tell you a few things about the gt42 turbos made for detroit diesel 60 series engines. They are a competitive copy of the KKK K31, BUT the compressor wheel seems to be radically more agressive. The GT42 is easy to spot because of the detroit diesel logo cast on the compressor cover, but I know that volvo and cat used them as well. I will speak mainly on the ones DDC put out there as they are pretty easy to come by. The color of the tag has meaning red=remanufactured, green=OEM. One should be aware that DDC/garrett had trouble with compressor wheel faliures on early GT models the redesigned ones are marked GTA on the tag. Next there were GT4294 AND GT4202 turbos used on 50-60 series engines, My 4202 is from a 500HP 14.4L the 4294 is found on lower HP 14.4-12.7L engines. There was a 50 Series engine as well (4 cylinder 60) which was used in transit buses, it had an oddball GT4294 with a .91 A/R T6 turbine which was gated. That .91 housing is not an A/R available from garrett as a service part, so if you find one it might be worth fooling with. The exhaust housings are interchangable between all the Gt42's. A/R's were available in .91, 1.01, 1.15, 1.28, 1.44 gated and non-gated and possibly other A/r's as well. There were a few real low HP models with the GT4088.
Hope that helps.
Yes it does :D
Thank you.
1990 W250 non ic'd. Under the knife again.
dvst8r
How'd it hook?
Postby bgilbert » Sat Nov 15, 2008 6:16 pm
stillsmokin wrote:
bgilbert wrote:there's one more hook this year and I intend to at least try to scare a duramax owner or 2.
Hook to the sled yet?
bgilbert
Re: How'd it hook?
Postby bgilbert » Sat Nov 22, 2008 7:09 pm
Hmm, must've took it out the gate. Maybe it's STILL draggin the sled. :shock: :lol:
bgilbert
Postby pulltilbroke » Sat Nov 22, 2008 10:47 pm
me and stillsmokin never made it to that hook, I was busy putting a clutch in and jeff was workin a few bugs out of his truck
We'll keep you posted though, the next hook is in February
Postby bgilbert » Sat Nov 22, 2008 11:07 pm
pulltilbroke wrote:me and stillsmokin never made it to that hook, I was busy putting a clutch in and jeff was workin a few bugs out of his truck
Those bugs can be tough. A buddy of mine with a 1st gen p-pump puller has been trying to work out the bugs for about 3 or 4 years lol. Lots of disappointment, trailer to the event, wait, wait and wait some more to hook, then when it comes his time, break at the line, not get off the line, charger won't spool, toooo much bounce during the first 100 feet etc etc. He's just about got it figured out now. I think he's got the truck to lay down now, but it took the past few years and the last pull of the season this year to do it.
bgilbert
Postby pulltilbroke » Sun Nov 23, 2008 12:32 am
Yeah it took me a little while to get my truck setup right but its workin pretty good now
I guess we'll see how it works next year with more power
Postby mhuppertz » Sun Jan 04, 2009 7:48 pm
oldschooldodge wrote:Cool video. That truck came alive once that big single lit.
Good music too. Reckless Kelly has to be my favorite band of all time.
Which Reckless Kelly song is in the video?
mhuppertz
Postby pulltilbroke » Sun Jan 04, 2009 8:30 pm
Seven Nights in Ireland
Postby DTanklage » Thu Mar 05, 2009 9:59 am
stillsmokin wrote:
So here's the setup:
*NV4500, 1 3/8 input, improved 5th mainshaft
did you measure your input shaft? not trying to be a bg, that for sure, but sb said mine ('97) was 1 3/8" and it only measures 1.220 (10 spline)
maybe your trans was outta a chevy or something else dont think they ever used larger than 1.25 in dodge trucks (some older trannies were only 1"!
DTanklage
Postby KTA » Thu Mar 05, 2009 1:25 pm
1.25 is the stock size nv4500 shaft. The 1 3/8 is an aftermarket upgrade.
Postby DTanklage » Thu Mar 05, 2009 3:58 pm
quad4x4 wrote:
Dodge HD Input Shaft..........1 1/4" 10 spline with .750" pilot tip diameter
Dodge LD Input Shaft..........1 1/8" 10 spline with .750" pilot tip diameter
GM Input Shaft....................1 1/8" 10 spline with .590" pilot tip diameter
Dodge 4x4 Output Shaft.......HD: 29 spline, LD: 23 spline
Dodge 4x2 Output Shaft.......HD: 31 spline, LD: 30 spline
GM 4x4 Output Shaft...........32 spline
thats off the quad 4x4 link
funny thing is that they didnt mention that the early dodge units were a 1" 19 spline
why all the diff splines for the output?????
make ya dizzy
DTanklage
Postby pulltilbroke » Sun Aug 16, 2009 4:02 pm
Well it finaly happend Jeff finaly got to make a few hooks with his truck.
First hook went 259.6 with a heavy sled and ended up 2nd and went 314 in the heavy class finishing 4th, still got some front end issues to figure out but all in all it was a great weekend for Jeff
BTW this is still with a 12mm H/R
http://www.youtube.com/watch?v=cVqZH5rh-hk
http://www.youtube.com/watch?v=v7QnCuXLWhg
Postby Ezra » Fri Oct 02, 2009 2:07 pm
That is sweet.. Is that truck runnin a 2.5lift? :evil:
93 W250,auto,3.54's..167k miles..asa modified intake.stans 4in,.industrial injection pump.6x.016's..S300 62/71/14..piston lift pump..And still more to come.
Ezra
Postby pulltilbroke » Fri Oct 02, 2009 3:54 pm
4" lift with gasser front leaves
Return to Competition
