Diesel Modified-class Tractor Pullers
Postby KTA » Sun Apr 27, 2008 10:12 pm
That is a DT466 based International motor NOT a Cummins.
Postby cummins king » Mon Apr 28, 2008 4:51 am
i know it was an international motor i thought Flash made a mistake but looks like im in the wrong
joel
93 4X4 auto
cummins king
Postby flashgordon » Tue Apr 29, 2008 8:24 pm
Yup thats the one. thanks for posting up the pic for me :thumright:
Thanks or the clarification KTA........pretty spectacular bang any ways :lol:
So do you thing it was "100 psi" of boost that killed it..........or are them engs just weak in that area.
Flash
flashgordon
Postby KTA » Wed Apr 30, 2008 2:39 pm
Typically those tractors run 200+psi, they can take a lot more cylinder pressure than the 6B can because they are wet sleeved and much heavier built. Those blocks do typicaly break along the cam, bore though as that is a weak area. The Deere blocks break the same place.
Postby cummins king » Wed Apr 30, 2008 6:24 pm
some cummins run up to 110psi+(maby more?), when fully biult, but i think stock they split around 90psi but it depends on wear i guess
but 200psi thats awsome, i guess that hx82 is a huge smoken turbo
93 4X4 auto
cummins king
Postby KTA » Thu May 01, 2008 12:55 pm
Of course some versions of HX82's can be run as singles on the 5.9. :)
Postby SChandler » Thu May 01, 2008 4:14 pm
:hs: I bet that takes a while to spool. Is that truck 2wd?
SChandler
Postby Begle1 » Thu May 01, 2008 4:30 pm
Yeah, that would be the biggest turbo I've ever seen as a single in a pick-up... :shock:
Postby cummins king » Thu May 01, 2008 4:54 pm
:shock: :jumpsmile: :hs: i bet that came off just as fast as it went on, thats huge, that would be awsome on a triple setup
is that some sort of injection beside the etgs gauge
93 4X4 auto
cummins king
Postby KTA » Thu May 01, 2008 8:03 pm
It is not as big as it looks, at least not wheel size anyway. It spools fine in a sled pull application, it would suck on the street though. That is the drive pressure sensor for the datalogger beside the egt.
Postby bgilbert » Thu May 01, 2008 8:12 pm
cummins king wrote:i bet that came off just as fast as it went on,
CK must not have been around too many big hp pulling trucks :lol: .
Is that George's truck? Air to air setup eh?
Bill Gilbert
Postby SChandler » Thu May 01, 2008 10:17 pm
I'm guessing that truck isn't running a VE pump. Double Overtime (Mod-class 7.3l powered truck) runs two of those in a compound configuration. I'm guessing other mod class trucks run those or something similar to that. Does that truck run in a bushing class or are they running an unlimited single turbo class?
SChandler
Postby cummins king » Fri May 02, 2008 4:44 am
no i dont know much about all the pulling stuff i thought on the street, but i guess in a pull you would be going off the line making a ton of boost, right
93 4X4 auto
cummins king
Return to Competition
Users browsing this forum: No registered users and 84 guests
