VE trucks from dyno day this weekend
Postby pulltilbroke » Mon Apr 26, 2010 3:31 pm
Re: VE trucks from dyno day this weekend
Postby IowaCummins » Mon Apr 26, 2010 3:56 pm
andrew thanks for posting these. i am in the process of doing a lift pump and 1/2" lines now. i was so pissed to see those low numbers and no rpm at all. i mean 2700rpm that was it lol. but your truck pulled to 3700 and sounded frickin awesome man.
IowaCummins
Postby pulltilbroke » Mon Apr 26, 2010 4:08 pm
Not a problem Steve, Can I ask you again why the hell you havn't upgrade your lift pump again :?
Postby IowaCummins » Mon Apr 26, 2010 4:13 pm
haha umm? hmm well heres a go, i was building the truck with all supporting mods like turbo injectors headstuds and air filter, so that i can have a great foundation for power when i surprize my self with a lift pump. lol
IowaCummins
Postby Mark Nixon » Mon Apr 26, 2010 7:15 pm
Steve, I have a LP piston pump set-up (lines, pump, spacer, the whole bit), that you can try to see if it helps your situation any.
If it does, it'll be a bargain.
Edit:
Looks like you're beyond that!
Postby IowaCummins » Tue Apr 27, 2010 5:59 pm
hmm now i gotta thinkabout this! tryin to decide engine powered or electric? i have seen what a engine mounted one will do when they go bad "mark your 96" and have heard of electric pumps failing. i will let ya know mark and thanks for the offer
IowaCummins
Return to Competition
