1st gen run at IRP
1st gen run at IRP
Postby bgilbert » Mon Jun 04, 2007 1:39 pm
Seen a 1st gen dyno in Indy (IRP), looked just like my truck, only less HP :lol: :D . Guess I should've taken the late Pastor Bob's advise of not doing too many things at once. Changed injectors, intercooler/aftercooler and timing (pump gear advance, ksb locked). I'm hoping it was just too much timing and or small turbocharger. I've got the pump gear advanced a tooth, and the pump head still almost up against the head. I also stuck a cold beer can between the power steering pump and injection pump (against the ksb) to make sure the wax pellet, or whatever the term is, was at the cold start point. Then unplugged it. This way nonIC'd style, the pump would be locked in advance.
423hp/801ftlbs down from 450hp/918ftlbs. Not what I was looking for, but I'm gonna back off the timing and try a bigger single charger (Pro52).
Link to dyno run video: http://www.youtube.com/watch?v=xuW6XSiRAZ4
I will say I made more power at a higher RPM compared to my 450hp dyno run last year at Scheid's event. Scheid event I made 400hp at 3000rpm. 350hp at 3200rpm. Little to no HP beyond 3200rpm. This run I made 423hp at 3000rpm, 400hp at 3250rpm, 350hp at 3500rpm. Run out to about 3800rpm :shock: . Pic of the dyno sheet on DTR, viewable once approved: http://www.dieseltruckresource.com/pics ... user=33726.
Bill Gilbert
bgilbert
Postby CAJUN 93 » Mon Jun 04, 2007 2:34 pm
my old man used to fuss at me on the racecar. i'd spend all week changing parts and spending money only to go to the track next weekend and slow down :lol: . still great numbers though. just need some fine tuning.
daryl
CAJUN 93
Postby PToombs » Mon Jun 04, 2007 5:32 pm
Bill, I think you are lying! :shock: I think the beer can was warm, because it was empty! :D
Postby bgilbert » Tue Jun 05, 2007 10:18 am
PToombs wrote:Bill, I think you are lying! :shock: I think the beer can was warm, because it was empty! :D
It should have been! My run at Scheid of 450hp, I didn't unplug the ksb for very long, so I'm sure it never cooled down enough. I don't know how ole Stomp, Mike and KTA ran so much timing and made such big numbers :oops: . Back to the drawing board lol.
bgilbert
Postby KTA » Tue Jun 05, 2007 1:44 pm
I am guessing it is probably because of twins instead of a single turbo. 8)
Postby bgilbert » Tue Jun 05, 2007 2:11 pm
KTA wrote:I am guessing it is probably because of twins instead of a single turbo. 8)
Yeah yeah I hear ya. If I could only sell my crew cab, I'd have twin money :? .
bgilbert
Postby KTA » Wed Jun 06, 2007 4:30 pm
Hey I made ya an offer! LOL Or I'll build ya a set of twins in exchange for the crewcab. 8)
Postby seeker1056 » Thu Jun 07, 2007 7:24 am
you can build a set of twins for under a grand if you shop Ebay, and can fabricate
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby bgilbert » Thu Jun 07, 2007 8:22 pm
seeker1056 wrote:you can build a set of twins for under a grand if you shop Ebay, and can fabricate
If I could weld and fab I'd have a killer twin setup. I have at my disposal two very good medium/heavy duty junkyards where S400's, HT and HX60's, S300's and others can be had in good shape cheap. Not to mention all the elbows, flanges, clamps, fittings etc one would want. Just today I went and picked up a downpipe and oil inlet fitting for this Pro52. Then grabbed a s400 elbow for a friend. Cheap too 8) . Maybe someday I'll learn how to fab. I need to get out of trucking for awhile and take a job in a machine shop or the like.
bgilbert
Postby whereswaldo250 » Thu Jun 07, 2007 9:27 pm
Great vid love the smoke :P
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Return to Competition
