Me and Jeff made a couple more hooks.
Postby pulltilbroke » Sun Aug 22, 2010 1:22 am
Had our last fairly local pull last night.
Me and Jeff did pretty decent In the 8000lb 2.6 class I went 394' 11" and ended up 6th and Jeff went 405'3" and was 5th, For grins and giggles we also pulled in the 2.8 class and I went 412'6" and ended up 4th and Jeff went 414'5" and was 3rd
I now have a coolant leak that I need to track down i think its just dripping out of the weep hole in the pump but I'm not sure.
Video will be up tomorow.
Re: Me and Jeff made a couple more hooks.
Postby oldestof11 » Sun Aug 22, 2010 11:16 am
Wait. You pulled 2.6 and did ok. THEN you proceed to the 2.8 class and did BETTER.....??????
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Postby pulltilbroke » Sun Aug 22, 2010 12:45 pm
Postby pulltilbroke » Sun Aug 22, 2010 7:13 pm
After a close inspection of everything the only carnage was a leaky water pump, and I also popped one of the spots where I soldered the rad. I also destroyed another set of motor mounts.
Postby stillsmokin » Sun Aug 22, 2010 9:17 pm
oldestof11 wrote:Wait. You pulled 2.6 and did ok. THEN you proceed to the 2.8 class and did BETTER.....??????
Yep, we did pretty good and both drove them up on the trailers at the end of the night, others weren't so lucky.
92 W250LE REG CAB, SLED PULLER, S400
93 W350LE EXT CAB, dually, 5 speed
stillsmokin
Return to Competition
