Stillsmokin and CaptainChryslers dyno runs
Re: Stillsmokin and CaptainChryslers dyno runs
Postby KTA » Thu Nov 18, 2010 2:41 pm
I don't know what you are running for compression, but I would bump the timing up another 6 degrees at least and go from there. You still might find you need to back the fuel off some more at that point but it should be alot stronger. I find 34-36 with the light is a good place to be for a 2.6 engine and compressions in the 14.5-15.5 range. Guess it is time to put a big shaft NV4500 in there!
Postby CaptainChrysler » Thu Nov 18, 2010 3:20 pm
4500 is rebuilt, waiting to go in.
It is stock comp. except for .020 HG. Can't really go higher on the timing and still be in the bowl. We have a to do list for the winter.
CaptainChrysler
Return to Competition
Users browsing this forum: No registered users and 76 guests
