drag times
Re: drag times
Postby cummins12club » Sat Aug 18, 2012 7:50 am
my fastest pass to date was 16.35 quarter mile, this is in a club cab 93 518 auto w od off thats w an hx35 building 35lbs of boost, stock injectors, 4k gov spring denny t 2 fuel pin, the usual ve pump stuff and thats it, 3.73 gears w 33 inch tires
cummins12club
Re: drag times
Postby oldestof11 » Sat Aug 18, 2012 8:40 am
Throw it in OD and I bet it will come down to near 15s. ;)
Re: drag times
Postby cummins12club » Fri Dec 21, 2012 8:21 pm
Last pass of last season was 15.71 w same stuff as above w new stock style lp launching at 1600 shifting at 2900 every gear including into overdrive I now have an ht3b under that 35 5x18 injectors valve springs air dog w fuel sump and line pressure turned up on tranni I'm hoping for 13s
cummins12club
Re: drag times
Postby Sutter1stgen » Sun Dec 23, 2012 11:08 pm
14.70@90 this was at freds truck drags. Oct ? I launched at 10 psi and was letting off a few times, egt issues!!! 1800+. Come to find out I had a 2" section missing of the gasket of my hot pipe flange. So there was a huge drive pressure leak. I launched at 15psi the last pass of the day and pulled off a best of 14.50@90. I'm hoping a smaller tire will help considering I have 3.07 axles. 13s are my goal.
Eric
Sutter1stgen
Return to Competition
