1410 front drive shaft
Postby cumminscloud » Wed Feb 23, 2011 8:14 am
been wanting to upgrade my front drive shaft ran into alot of problems andbody have a solution for this would like to go 1410 yokes is this possable thanks
cumminscloud
Re: 1410 front drive shaft
Postby BILTIT » Wed Feb 23, 2011 12:54 pm
This is the man to talk to-jesse.
http://www.highangledriveline.com/
Derek B.
BILTIT
Postby cumminscloud » Wed Feb 23, 2011 8:01 pm
thank you
cumminscloud
Postby KTA » Thu Feb 24, 2011 7:52 am
You can put up to a 1480 yoke on the ring and pinion end. The problem is the trasnfercase end. Getting a big CV joint is hard to come by.
Postby GLHS » Thu Feb 24, 2011 9:21 am
I put a 1410 on the D60 and used a 1350 on the transfercase side.
The weakest link is the D60 side.
If it's a 89-92 it is tiny. The 93s are bigger.
GLHS
Postby rockjeep73 » Fri Feb 25, 2011 8:14 pm
On my brothers truck we went to a 1410 on the Dana 60 end and are still running the stock 1310 cv at the t-case, haven't had a problem with it at 900hp.
2000 QCLB 2500 4x4, 12.05 @ 111
89 D-250, In The Graveyard
89 W-250, Mostly Stock
http://www.SHSDiesel.com
rockjeep73
Postby ahale2772 » Wed Mar 02, 2011 8:40 am
Rockjeep, do you run the upgraded np205 output?...or maybe you dont run an np205?
Postby rockjeep73 » Wed Mar 02, 2011 4:16 pm
We ran a stock 29 spline 205 and never had a problem with it at the 700hp level. With the last round of upgrades we went to a 271, 900+ hp now.
rockjeep73
Return to Competition
Users browsing this forum: No registered users and 75 guests
