Keeping my auto alive?'s
Re: Keeping my auto alive?'s
Postby 93 W350 LE » Mon Jun 17, 2013 7:37 am
Any recommendations on a mounting location? This should get plumbed in before the factory water cooler to help keep engine coolant temps down as well? Run the fan off a thermostat and switched power?
Thanks for any input.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Postby 93 W350 LE » Tue Jun 25, 2013 4:23 am
So I go to ky local NQPA for a filter, and they tell me they obly show for a 727 nothing for the 518. What gives? Anyone have a part # I can maybe give them?
Thanks.
Eric
93 W350 LE
Postby cmann250 » Tue Jun 25, 2013 3:05 pm
I am 90% certain the filters, gaskets, and pans are interchangeable on 727s through 47REs and maybe 48REs. I'm not an expert though :lol:
If you do not have one already, I would suggest a reusable gasket. The pan gaskets that come in all the filter kits that I've had were of poor quality. I believe you can get a reusable gasket at the dealer and maybe other places. They were supposedly OE, but you don't know if the PO threw it away 20 years ago until it's too late.
Postby 93 W350 LE » Tue Jun 25, 2013 7:02 pm
I thought the 518 was just a 727 with overdrive. Is this right?
Eric
93 W350 LE
Postby cmann250 » Wed Jun 26, 2013 4:39 am
Essentially.
Postby Sutter1stgen » Sat Jun 29, 2013 7:06 am
93 W350 LE wrote:I thought the 518 was just a 727 with overdrive. Is this right?
Eric
In a diesel application I'm posetive! I swapped my 727 pan over when I updated to the A518. Same filter and gasket as well.
Eric
Sutter1stgen
Postby mopargoob » Mon May 27, 2019 5:52 pm
the 727s use an old style filter that has 3 screw holes, and a metal band around the outside of the element which is a "cloth" style. the newer 46, 47 and 48s use basicly the same filter but it is encased in a plastic housing on one side and stamped steel on the other. when we rebuild them, we crack em open to see how much filings and metal is in them so we can determine if it's worth rebuilding, or just swap in a reman unit.
mopargoob
Return to Transmission
