Getrag Input Modification
Postby ellis93 » Thu Feb 16, 2012 7:01 pm
Ok I was talking to Mr Mark the other night, inquiring about a used input before I bought a china unit. In our conversation he brought up the idea of enlarging the lube orifice for the pocket bearing,which I thought was a grand idea. As I've tore into and rebuilt my rag I've thought about doing something a little more radical.
If you look here,you'll see a fairly tiny slot,ONE slot for lube to reach that horrid pocket bearing. I'm GOING to at least open it up on the inside to match the outside machining grove
Inside pic
Ok here's my thought,if ya'll think its crazy say so.
I want to turn the input 180 degreas and cut another slot in it.
Only possible down fall I can see is maybe weakening it for fourth gear,seeing as fourth is direct.
Any thoughts? ;)
Re: Getrag Input Modification
Postby ahale2772 » Thu Feb 16, 2012 7:09 pm
I think its a grand Idea
Postby CumminsPower59 » Thu Feb 16, 2012 7:13 pm
I would say go on the second opening, since it's going to be 180 degrees from the orginal, and if its going to be the same size, I don't see why that would be an issue. From the looks of it, there shouldn't be any structural issues with doing so, I believe only good can come from it with more lube going to the pocket bearing ;)
Postby ellis93 » Thu Feb 16, 2012 7:14 pm
So you don't think I'd rip the butt end off when I tow with it :lol: I haul some mean loads.
8)
Postby ahale2772 » Thu Feb 16, 2012 7:19 pm
I dono... no way to tell really.
When you increase the radius, of any circular piece, it is inherently stronger. hence I think it is still going to be stronger than the input shaft (splined part) itself.
I coullllllllllllllddddddddd work up a FEA on solidworks, and actually virtually test it.... but that would take a few serious hours, and im bogged down with work untill next week, I dont know if you want to wait that long...
but im willing to give it a try...
Postby ellis93 » Thu Feb 16, 2012 7:37 pm
I appreciate that alex but I'm putting it together tomorrow night cause I've gotta go get a new old tractor sunday. I'm in the thinking it would twist that nose in two before that back would break
Postby ahale2772 » Thu Feb 16, 2012 7:39 pm
I agree... I say you try it
whats the worst that could happen? you get stuck in the middle of nowhere, on a hill, towing a huge load?!?!?! no big deal.... :roll:
Postby ellis93 » Thu Feb 16, 2012 7:48 pm
Shoot, with this trans,I take that risk every time I pull.
Don't sound like your very sure of my idea :sad:
Postby ahale2772 » Thu Feb 16, 2012 7:55 pm
I do like the Idea, and I still think the input would twist off before the back half.
if you want to give me some quick measurments, I can do a few silly calculations to make you feel better.
if I had a aproximate cross sectional area of both areas, I could figure out which would take longer to break... even under shock loading
Postby ahale2772 » Thu Feb 16, 2012 7:58 pm
thing is, the splines on the input dont provide much strength at all, besides just shear strenght so that the clutch splines dont shear them off.
all the strength is in the base of the splines, and thats not much more than 1 inch...if that....keep in mind the center of a solid bar Bears NONE of the rotational strength under torsion
hence why a willys jeep has a solid shaft for a driveshaft, and a new pickup has a large diameter hollow tube... the bigger the radius, the strongger the piece.
Postby ellis93 » Thu Feb 16, 2012 8:04 pm
I'll take the measurments in the morning when I'm around it. I'll post it up asap. Thanks alex
Postby ahale2772 » Thu Feb 16, 2012 8:07 pm
Yup, no problem.
try and get me a measurement of what it would be like if you sliced the input at both points, Know what I mean?
thats some pretty easy stuff thats right out of the book, force over area, yet the big issue is shock loading, which is also in my textbooks, so I should be able to get you a Max rotational tourque that each piece should handle
Postby ellis93 » Fri Feb 17, 2012 6:14 am
Alex, the shaft diameter is 1.230,measured here:
The outer diameter of the surface were the slot is, is 2.770. Measured here:
Inner measurement is 2.275 measured here:
Postby ahale2772 » Fri Feb 17, 2012 7:10 am
Ellis, just remembered I have an input here that I can take measurements off.
Postby Horus » Sat Feb 18, 2012 2:06 am
Great topic. I have a few thoughts/questions.
So nobody is producing an American made input shaft anymore? Does that go for the nv4500 and 5600 crowd too?
I've seen the idea of machining the input to accept a race for the pocket bearing. Does anyone have a part # for a pocket bearing and race? Seems like a great way to keep an original German shaft in place after a rebuild.
I cannot wrap my head around machining more oil grooves into the input. If anything I would be more motivated to weld up the one it comes with. If I'm not mistaken we overfill our Getrags to keep the upper bearings submerged partially in oil. This includes the pocket bearing. The input shaft is always spinning. I don't see how any oil could make it through the slot and into the bearing before it is wicked away by centrifical force. The oil has a far better chance of getting into the bearing if it is pooling against the bearing assembly on the mainshaft side.
Maybe if you spotted and drilled some small holes in the saame area and angled them through the shaft at about a 45 degree angle. If they were angled toward the direction of rotation they might act to pull the oil through as the shaft spins, like an impeller.
91.5 W250 Dodge 4X4 CTD. Getrag. DD Power pin removed, stock fuel cone back in. 366 spring. Power screw at stock depth. Stock turbo. Stock lift pump. Straight piped and Intercooled.
93 D250 Dodge club cab 2wd. All stock for now. Automatic.
Hard KOR Wheeler.
PNWJeep club member.
Horus
