47rh adapter vs 518 adapter
Postby DodgeFreak » Thu Nov 08, 2012 6:16 am
I've got everything to convert my 518 to a lock up. my question is....does anyone know exactly how much thicker the 2nd gen adapter is??? I'm thinking of just making a spacer for it instead of swapping adapters then when I source parts to make my other one i'll use the adapter I have.
Re: 47rh adapter vs 518 adapter
Postby tampabayBill » Thu Nov 08, 2012 7:20 am
Didn't measure mine, but am pretty sure its 1 inch.
Twins coming soon!
tampabayBill
Postby ellis93 » Thu Nov 08, 2012 11:07 am
tampabayBill wrote:Didn't measure mine, but am pretty sure its 1 inch.
That's how I've heard it too.
Postby DodgeFreak » Thu Nov 08, 2012 12:29 pm
Thats what I've heard also...Maybe I'll just get a wild hair over thanksgiving and pull the engine and trans out of the donor truck for kicks and giggles and report back....
