Trans swap
Trans swap
Postby 90chum » Sun Mar 24, 2013 4:26 pm
I have a '90 auto and the trans is almost junk, I bought a 4wd 47rh and have the wiring, etc... To put it in, and was planning on a hefty rebuild. But I was on Craigslist and found a 2wd getrag with hydros, not sureif it comes with pedals. So my question is how hard would it be to make the rag 4wd? Or should I stick with the rh?
1990 w250 RCLB auto-some stuff to make a constant haze, diamond eye 4" straight, 47rh with goerend triple disk and suncoast innerds, body panels and more panels. shes occassionally referred to as a dirty slut, but usually just chum
90chum
Re: Trans swap
Postby Mark Nixon » Thu Mar 28, 2013 7:39 am
If you're going to go 5 speed, you'll need the parts to convert the trans to 4WD and either the conversion coupler for the auto t-case, or the hen's teeth hard-to-find 29 spline transfer case.
You'll also need some driveshaft work, too.
Since you're wanting to get away from the 3 speed auto, the options are either expensive or VERY expensive. :roll:
With that, the 3 speed can be rebuilt for under a grand, if you don't mind a slow truck.
Re: Trans swap
Postby rockbuggy4x4 » Mon Apr 08, 2013 12:34 pm
What would be needed to complete a 727 to 47rh swap?
rockbuggy4x4
Re: Trans swap
Postby dazedandconfused » Mon Apr 08, 2013 1:06 pm
Driveshaft alterations and moving the cross member. You will also need a 2nd gen adaptor plate and starter. I believe the t-case will work since the 47 has a 23 spline output as well.
http://1stgen.org/viewtopic.php?f=3&t=2126
Re: Trans swap
Postby rockbuggy4x4 » Fri Apr 12, 2013 9:42 am
Ok, that's what I thought. Thanks.
rockbuggy4x4
Re: Trans swap
Postby dunes450r » Fri Apr 12, 2013 5:00 pm
if you want to do the getrag swap with the 4wd trans, no driveshaft of crossmember mods are necessary.
dunes450r
