anyone use a valair heavy duty clutch master and slave ?
Postby jmd4993 » Mon Dec 02, 2013 6:22 pm
i just did a getrag swap and put in a valair dual disc and i was told that the stock master and slave assembly wears out fast with the heavier clutches. but valair has a heavy duty hydraulic assembly but its only for 94+. i called valair and they said that they know that guys have used it on first gens but dont know exactly how.
jw if any one has done this thanks
jmd4993
Re: anyone use a valair heavy duty clutch master and slave ?
Postby jmd4993 » Tue Dec 10, 2013 1:23 pm
I called valair and they said that there is no difference between their hydraulic clutch assembly and a stock one except theres has a thick metal line. but all the pressure ratings seals are the same. and you dont need a heavy duty slave to operate the dual discs they said. also the dual disc is not heavier than the stock cast iron clutch so you nothing it different.
jmd4993
Postby BILTIT » Tue Dec 10, 2013 1:31 pm
I run a dual disc with stock everything else, works fine.
Derek B.
BILTIT
