getrag swap questions
Postby Flat bed cummins » Tue Apr 01, 2014 7:02 pm
I was wondering about the nv4500 swap, my getrag is going out. I can get a nv4500, but what else would. Need? Is it easier to get an adapter from advanced adapter or is there any other places that are better?
1993 cummins 5 speed 4x4 flat bed. The previous owner turned the pump up so it smokes too much for me, transmission swap getting ready to happen
Flat bed cummins
Re: getrag swap questions
Postby Flat bed cummins » Wed Apr 02, 2014 7:51 pm
Am i not asking the question correctly?
Flat bed cummins
Postby RCCUMMINS89 » Wed Apr 02, 2014 9:04 pm
You can either get the kit from Advanced Adapters.... Or you can use the bellhousing, engine adapter, and starter from a 2nd gen truck.
Postby 92cummins89 » Thu Jul 10, 2014 9:23 pm
I just did this in mine just go with advance adapters
Pretty straight forward
92cummins89
Postby brandonmgreer » Sat Nov 22, 2014 1:38 pm
I know this is and older thread. but I'm about to swap a 4500 for my worn out getrag. I have access to a totalled (rolled over) 2001.
Are the adapter, starter, bell housing, hydros the same on a 12v and 24v? I can get all of the parts I want from it...
What do I need to grab? Clutch pedal assembly, hydros, adapter, starter, flywheel, tranny, shifter? Anything else? Whats the difference in length on a getrag and 4500? will i need to lengthen/shorten my driveshafts?
Thanks in advance.
White/black 92 D250 manual conversion, Pump tweaking is about it right now...
95 CCLB 4X4 5 speed being but back together from a wreck
99 Kenworth W900 flat top, Tuned 500 Detroit, BW 75mm 1.32A/R, 5915 injectors, 13 speed, 3.55's
brandonmgreer
Postby Philip » Mon Nov 24, 2014 6:25 am
The pedals won't work. The hydros will if you have a 1st gen M/C push rod. The push rods are different lengths between the 1st gen's and FRT's. You will need the M/C mounting bracket under the dash. That 01 will not have it.
You can use the engine adapter/ starter/ flywheel and clutch.
I can't say on the length differences.
Postby brandonmgreer » Mon Nov 24, 2014 6:48 pm
FRT???
The rest, I got.
I just wanted to make sure if there was or wasn't a difference in parts on the second gen 12 and 24 valve.
brandonmgreer
Postby Philip » Mon Nov 24, 2014 7:56 pm
brandonmgreer wrote:FRT???
The rest, I got.
94+ year trucks. Flippen round trucks. The four letter word works best as the first word.
Postby txs » Mon Nov 24, 2014 9:11 pm
Brandon, you can use your pedals and clutch master cylinder, you will need the slave off of a 94-95-96ish I believe by 01 they had went to a smaller diameter slave. I learned this this the hard way, took about 2 years but I destroyed a 750$ centerforce clutch by using the smaller slave, when used with the 1st gen master it overtravels the clutch diaphram spring. do be sure and grab the plastic line, the first gen line was too short for the 5600, and the 4500 may be the same way. If you use the 01 line you will need to put the fitting that pins into the first gen master into the 01 line.
txs
Postby PToombs » Tue Nov 25, 2014 5:50 pm
Funny Round Trucks. :lol:
Postby txs » Wed Nov 26, 2014 8:18 am
Pete, that's not the adjective I use.
txs
Postby PToombs » Wed Nov 26, 2014 7:28 pm
Yeah, I know, you and Philip are from the same generation and use the same words. :lol: I use those words too, but only when I'm working on it. :evil:
Postby brandonmgreer » Mon Dec 01, 2014 11:53 pm
FRT... thats funny.
Thanks a bunch for the info, guys! :grin:
brandonmgreer
Postby 93oneton » Sun Dec 07, 2014 8:50 pm
I just did a nv4500 swap in mine. I used the advanced kit. It worked really well. Just my 2cents.
Shit happens
93oneton
