A518 trouble
A518 trouble
Postby davedv85 » Thu Apr 24, 2014 10:11 am
My trans lost all forward gears but I still have reverse. I found a 727 for a Cummins. Besides losing overdrive what other problems may I have switching it over
davedv85
Re: A518 trouble
Postby DodgeFreak » Thu Apr 24, 2014 10:14 am
Drive shaft is a different length.
Re: A518 trouble
Postby DodgeFreak » Thu Apr 24, 2014 10:15 am
Do you have manual 1st?
Re: A518 trouble
Postby davedv85 » Thu Apr 24, 2014 10:17 am
Do you know the difference in drive shaft lengths.
davedv85
Re: A518 trouble
Postby davedv85 » Thu Apr 24, 2014 10:18 am
I do have a repair manual if that's what you were asking
davedv85
Re: A518 trouble
Postby DodgeFreak » Thu Apr 24, 2014 10:29 am
No I mean Manual first gear. Drive doesn't apply the rear band in first but Manual first applys the rear band. Hopefully Cmann will see this because he just swapped a 518 inplace of his 727. Is yours 2wd?
Re: A518 trouble
Postby davedv85 » Thu Apr 24, 2014 10:32 am
I've tried putting it directly in first gear and still nothing.
davedv85
Re: A518 trouble
Postby DodgeFreak » Thu Apr 24, 2014 11:37 am
Also with a 727 your top speed will be about 55mph. My 92 cab and chassis lost od and I was against the gov. at 60mph. which wasn't fun going down the interstate.
Re: A518 trouble
Postby davedv85 » Thu Apr 24, 2014 1:41 pm
I don't drive much on the interstate so wouldn't be to noticeable
davedv85
