my haunted aut0-ppo
my haunted aut0-ppo
Postby kwrank » Sat May 23, 2015 7:41 pm
so i dropped the trans pan, adjusted bands, new filter, gasket, five quarts fluid...and now nothing happens when i put shifter into any gear--it's like trans isn't even there...i've done this work before, so i don't think i screwed something up, but, well, seems like i did...thoughts?
92 W250 CC HX35/16 366 190's lp piston lift hughes converter
kwrank
Re: my haunted aut0-ppo
Postby kwrank » Sat May 23, 2015 8:00 pm
i should add i loosened the valve body and removed the bolts to get more fluid draining out...thanks
kwrank
Postby oldestof11 » Sun May 24, 2015 7:20 am
Did you pop the shift linkage loose when adjusting the front band?
Postby kwrank » Sun May 24, 2015 8:28 am
nothing showing on the dipstick this morning (at idle in neutral). was showing some last night. i'll get more fluid and report back. always leery of overfilling...it did move a bit this morning when stone cold. yes, i did take the linkages off, and they went back on without a fight for once, first thing i checked, as the shift lever feels awfully smooth :shock: :shock: thanks, k
kwrank
Postby Begle1 » Fri Jun 26, 2015 5:43 pm
Dollars to donuts that something popped loose on the top of the valve body.
I think I had the same thing happen to me at one point... I don't remember exactly what it was, something with a ball falling out of position in proximity to the rooster comb or something.
