Synchro Question!
Re: Synchro Question!
Postby Mark Nixon » Wed Mar 06, 2013 1:11 pm
bmoeller wrote:...May need an input for 5600 as well. Nose is worn where the bearing was...
Have the flywheel bored for a sealed bearing and the damage will likely no longer matter.
Postby bmoeller » Wed Mar 06, 2013 1:16 pm
I can have that done, when I get the flywheel touched up. :) It's not horrible, but I can catch my nail on it.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby PToombs » Sat Mar 09, 2013 1:55 pm
I think I found my rattle noise. Last time I reset the shims on the countershaft I noticed it seemed to move but nothing on the dial indicator. Today as I was assembling it I realized why, the gear cluster is loose on the shaft and will slide back and forth about 1/8 inch! So that job is on hold until I can get a shaft and snap rings. Figures. :roll:
Postby bmoeller » Sat Mar 09, 2013 5:44 pm
That sucks Pete! :?
bmoeller
Postby PToombs » Sat Mar 09, 2013 5:45 pm
Yeah, kinda what I was thinking as I was cussing! :lol:
Postby PToombs » Mon Mar 25, 2013 5:34 pm
Has anybody else had the countershaft cluster be loose on the pin? I've been thinking about it and am not sure if the cluster is supposed to be a friction fit on the pin, or are the bearings supposed to hold it when you tighten them down with the rear cover? I can't remember how it was when I pulled it apart the 1st time, and I've done it so many times now I'm not sure how it's supposed to be. I was talking with the guys at work and they don't think the bearings should hold it because they would have to have a lot of load to pinch it.
Let's hear it!
Postby Mark Nixon » Mon Mar 25, 2013 5:45 pm
There is a notable interference fit, but it's not a "press" fit.
Shouldn't be sloppy in the least.
Postby PToombs » Tue Mar 26, 2013 5:26 pm
Mark, once I tap it into position, (without bearings) I can slide it in and out by hand.
Ok, I figured it out, sorta kinda. I did some measuring tonight and the bearings should rest against the cluster. I think my pin was swelled from driving it in and out so much that the bearings were stuck too hard on the shaft. So when I shimmed it, the bearing wasn't moving back to the cluster, letting it float back and forth on the pin. I hope the cluster isn't too loose on the new old pin I'm getting.
Well, I'll find out!
