The time has come. New trans time.
Re: The time has come. New trans time.
Postby ellis93 » Sat Mar 15, 2014 6:04 pm
Bite the bullet and buy hydraulic hose(have them made up). It'll never leak,no worries :)
Postby cmann250 » Sat Mar 15, 2014 6:09 pm
Very possible. It looks like I'll be interning with the CAT dealer come May. Como se dice "employee discount"? :lol:
Postby ellis93 » Sat Mar 15, 2014 6:11 pm
Cat? Cool beans! What for?
Postby cmann250 » Sat Mar 15, 2014 6:14 pm
I want experience in industry, Cat is close, Cat looks great on a resume, and Cat has better chances to move up the ladder than a JD or IH dealer.
Postby ellis93 » Sat Mar 15, 2014 6:17 pm
What job guy? :lol: Mechanical or sales?
Postby cmann250 » Sat Mar 15, 2014 6:33 pm
Grunt. They have a huge rental division. Like 50% of the business. I interviewed with the rental manager and I'd answer to him and the shop manager. Sales, meh. That's fickle business.
http://www.macallister.com
Postby ellis93 » Sat Mar 15, 2014 6:46 pm
Cool.....you'll like it,in the shop I'm sure. You'll actually have tools to use.....appropriate tools :lol:
Postby cmann250 » Sat Mar 15, 2014 6:54 pm
Shade Tree Mechanic For Life!!!!!!!!!!!!!!!!!!!! :lol:
Postby ellis93 » Sat Mar 15, 2014 6:58 pm
Postby tampabayBill » Sun Mar 16, 2014 6:09 am
Hey Caleb, about time you got that thing together !! I knew you would like that converter. Enjoy !
Twins coming soon!
tampabayBill
Postby cmann250 » Sun Mar 16, 2014 2:04 pm
On the wiring-
I swear my ASTG manual had a diagram, but I can't find it now. I used this picture:
My circuit is good. I have the PATC connector and I sure think it's pins are too wide. The stock connector I got with my spare transmission fits a lot better. My fingers don't work so well at 26*, so on some warmer day I'll check to see if I bent the pins when I put the new connector in. If that's not it, I'll drop the pan and check the wiring inside. I'll test the solenoid and verify its position too. I should have tested it when I had it out :lol:
I'm still very happy with this converter and shift kit.
I did patch my cooler lines. My fingers are too cold to mess with the speedometer :roll:
Postby cmann250 » Mon Mar 17, 2014 2:24 pm
My driveshaft is on the books as of 7 this morning. The driveline guy suggested a 4" tube, so I said OK. They have everything in stock, but the guy is backed up so it'll be tomorrow or more likely Wednesday until I get it.
Postby dazedandconfused » Mon Mar 17, 2014 2:35 pm
Why 4"? Hell a factory shaft is only 3" or at least the one out of my donor was.
Postby cmann250 » Mon Mar 17, 2014 2:55 pm
My stock 727 shaft is 4". I think the one I cobbled together is 3". He said 3.5" or 4" and had 4" 1410 yokes on the shelf so that's how I went.
The guy builds the drive shafts for all the pulling trucks and drag cars for 75 miles around. I shut up and didn't argue :lol:
Postby cmann250 » Mon Mar 17, 2014 3:48 pm
Speedometer works. I got it clocked right in its bore.
My O/D solenoid shows 1600 ohms of resistance, so I'll be dropping the pan. Now, to order an aluminum or not? Hmmm...
