IrishChamp wrote:Should I just change my fluid and be done with it?
what about what Sutter suggested, adding a 2nd servo return spring?
Should I be making any changes to the shift kit, I have a TFOD Diesel shift kit installed. I do plan on doing a band adjustment. I'd just like to put my pan back on with my transmission in the best shape possible.ellis93 wrote:Silicone is used on motors and doesn't belo anywhere near a trans![]()
3m makes some stuff called weatherstripping adhesive,comes in yellow or black,that's what I use. Any parts store has it.
No harm adjusting the bands. More than likely that is what has worn enough to leave the deposits on your pan magnet.
As for the other, I'd adjust up the front band and see how that's treats you. If that doesn't produce the disired results then dig.
I try to keep to the K.I.S.S. Principal while messing with a trans and take baby steps so you keep track of what goes on.
That's keep it simple stupid
