by ellis93 » Fri May 13, 2011 6:36 am
Flow goes like this:filter-pump-regulator and fluid splits three ways. One feed the valve body. The other feeds a boost valve( and other stuff from there). The last feeds a switching valve that then feeds the converter and front clutch. From the converter, fluid flows back to the switching valve and from it to the cooler. From the cooler, fluid runs to lube the output shaft and rear planet in a 727, all of that would be intermediate in a 518. This is in neutral, as is similar in reverse first second and third with the exception of the boost valve supplying different things. Pressure in cooler lines could get as high as 95 pounds, so says the almighty ATSG trans manual.
