by Ptothej » Wed Jun 08, 2011 7:12 pm
I recently started to find my leaks under all of the gunk build up on mostly the t-case. I cleaned it off and found there to be hardly any leaks, and it stayed quite dry for the most part until... I loaded up my 5000lb boat and took off for the lake at 100km/h hitting one major hill in fifth gets my egts hot and nets me about 25psi I checked my leaks after the round trip and yep its started to leak decently between the tranny and then not the output shaft seals but the inspection plate? plus fill and drain plugs. Yes its a one owner and dude claims the clutch has never been done aka nothing has ever been apart, so seals are getting old at a million km's give or take, but like I said it seems to stay dry until I load her up, am I overheating the drivetrain, is the vent hose not venting possibly? Ideas? Has anyone come across this?
'92 W250, 5spd, reg. cab, 2" lift, 4" dp, 4"exhaust no muffler, smoke screw bottomed out, star wheel bottomed out, full power screw maxed, BD fuel pin, BD 16cm housing (30psi), K&N air filter with a modified factory air box
