I think it just needs to be checked and adjusted a few times after it gets rebuilt to get it right.
PToombs wrote: MM and I have discussed the oil pump/cooler/ squirters at length. Unfortunately, neither of us has time to build any thing, yet.
ellis93 wrote:PToombs wrote: MM and I have discussed the oil pump/cooler/ squirters at length. Unfortunately, neither of us has time to build any thing, yet.
This sounds,to me anyway,like a cool idea but don't the gears already sling oil everywhere. Well every where except the pocket bearing and then even the squirters couldn't get to it. With the one qt over fill aren't we already getting close to all the bearings?
I bought one of alex's covers awhile back and had hoped to have a coolings system made where I'd plumb into that clear cover with a suction and discharge. I was going to take a solid plug and cut a slit in the top and drill through the center to make a squirter of sorts. I thought it would resemble a pressure washer nozzle. I would take said nozzle and screw it to the discharge side and aim it at the input and main shaft, effectively cooling the syncros. I had also thought that at the same time to incorporate a cooler from an auto trans to lower and control trans temps. The only thing that has stopped me is finding a suitable pump to use in the oil and produce the pressure I want. Anybody know of such a pump?
Users browsing this forum: No registered users and 85 guests
