by txs » Fri Feb 03, 2012 7:31 am
Got the new clutch in and had van haisleys tranny guy (Brian) put the synchros in the 6 speed, i had been using penzoil synchromesh for some time as i had a leak and the amsoil, redline, and factory stuff was just to expensive. Brian said the bearings and every thing but the synchros (they were bad from the get go) looked great so i filled her up with synchromesh, its only 7 or 8 bucks a quart. He also said put in an extra quart just like you do the getrgs so i did that also. Only problem in the whole job was forgot to fill the new slave cylinder with fluid before install, had a hell of a time bleeding it out.
