m880cummins wrote:Not sure about the frame issue. Our 47rh fit right in there using that 2nd gen starter. About 1/4" clearance.
Charlie
CUMMINSDODGEMAN3 wrote:starter doesnt hit on mine neither, and you dont have to make any mounts. you can drill two new holes in cross member and will bolt right up.
Chuck Snider wrote:How are you guys controlling the lock-up converter?
cougar wrote:Were you located? I might be interested in trading you parts if the freight isn't too excessive. I have the column and pedal set out of a 93 I want to convert to a manual transmission.
cmann250 wrote:A 'lil birdie told me where a built 47RH is, along with adapter plate, starter, and 241 transfercase, should you want itSuncoast parts
revemup15 wrote:?
cmann250 wrote:revemup15 wrote:?
Does that ^ mean "Yes, Caleb I'm interested. Please tell me more."?
