auto trans rebuild tool list
Postby kabob » Sun Aug 05, 2012 7:00 pm
Im looking for a list of any special tools that I might need to do the rebuild job on a A518, and what the best manual is to use
Thanks
Josh
kabob
Re: auto trans rebuild tool list
Postby ellis93 » Sun Aug 05, 2012 7:27 pm
Get your self an atsg manual from where you buy your parts from,its the best I've found.
Look thru these two links
http://www.dieseltruckresource.com/dev/ ... p?t=160276
http://www.dieseltruckresource.com/dev/ ... ?p=1991156
You'll more than likely find the answer to what kinda tools you need
Postby DodgeFreak » Thu Aug 09, 2012 6:01 am
as far as tools the biggest one is a press.....i have a 12 ton harbor freight press that does the job okay....gets alittle scary pressing the od apart and the sides are flexing....then i just took 3 peices of 1\4 thick by 1.5-2'' wide i think, and put the interm shaft in and then made it about 2 inches taller, then welded them together, works okay, when you press it back together i have to use a rubber hammer and smack the drum straight, but it works decent, thats the only special tool i have,
and then to press the front band piston apart i bolt the case to the bench and i used a short piece of pipe with a flat steel across it then use a big c clamp.
might have to fab up another peice to press the front drum apart, cousin gave me his dads press stuff for the front drum when he passed away, so i didn't have to buy any of that.
Postby dodgeman1990.5 » Sun Oct 21, 2012 7:21 pm
there is a video of a guy doing it step by step on youtube. he is a little annoying but it looks pretty self explanitory it is for a 600 hp gasser tho but it should be pretty much the same http://www.youtube.com/watch?v=xzJhCBZ1wMY
dodgeman1990.5
Users browsing this forum: No registered users and 86 guests
