Getrag fluid change
Getrag fluid change
Postby hydroshok » Mon Sep 17, 2012 9:38 pm
I was reading in my owners manual and it says never to change the fluid. I know that must be wrong so what do you guys recommend for changing the fluid?
The manual also says to use ATF is that correct or should I upgrade?
hydroshok
Re: Getrag fluid change
Postby dunes450r » Mon Sep 17, 2012 9:59 pm
dunes450r
Postby hydroshok » Mon Sep 17, 2012 11:17 pm
Thanks, but what is the change interval?
Nice I just hit 25 posts so I can search!!!
hydroshok
Postby dunes450r » Tue Sep 18, 2012 7:35 am
i'll probly try for every 30k, we'll see though. can't hurt to change it more often, but it doesn't need it every 5 or 10k
dunes450r
Postby hydroshok » Tue Sep 18, 2012 8:07 am
Thanks!
89 D350 5spd 83 crew cab: waiting on new drivetrain
1999 2500 5spd: 2001 HO motor, smarty, edge comp, 40hp injectors, AFE intake, AirDog, rebuilt NV4500, HX40, full air ride
hydroshok
Postby CumminsPower59 » Tue Sep 18, 2012 9:33 am
I change it every 10k.
Postby PToombs » Tue Sep 18, 2012 4:33 pm
I change it 2 or 3 times a year. The way I figure it must be about every 1000 miles. It sucks to have tranny issues. :lol:
On a good note, I've found you really only need about 6 bolts to hold it in there. :mrgreen:
Postby hydroshok » Tue Sep 18, 2012 7:35 pm
I'd change it every month or few weeks if I did every thousand. I like 30k. It's better than never changing it like the book says. It is weird because if you don't use the right fluid in the NV4500; the syncros start to go, but you can do whatever you want with the getrag....
hydroshok
Postby RumbleFish » Tue Sep 18, 2012 7:38 pm
PToombs wrote:I change it 2 or 3 times a year. The way I figure it must be about every 1000 miles.
Only because you pull that trans that often!
Postby PToombs » Wed Sep 19, 2012 5:32 pm
Yup, and that's the only reason! :lol: Last time I filtered the oil and put it back in, gotta save money where I can! :mrgreen:
Postby GoldenRule » Mon Oct 08, 2012 12:20 am
Every 30k miles and fill through the shifter.
Mobil 1 5w-30 Extended Performance. It's available everywhere, comes in 5 qt containers (perfect size), and goes on sale regularly.
If you want to monitor your oil so you know if you actually NEED to change it, consider getting on an oil sampling program with Blackstone Labs. I do engine and trans with them and they maintain records online.
Another great upgrade that will probably be cheaper than changing the fluid every 1k miles is add a filter like this one: http://www.quad4x4.com/filterkits.html
They bolt on in place of you PTO cover plate and have a magnetic and particulate filter. Great way to monitor trans wear and add a little capacity! I run a cooler on driver's side and filter on passenger side.
GoldenRule
